Old 06-10-2009, 06:19 PM   #1
freestylinmotox's Avatar
Default Quick Question concerning O.S.
I was wondering if you can put a O.S. speed rod in a v-spec vzb? Are they compatitible? Same dimensions? differences between each rod? I would like to put a speed rod in my v-spec if possible. Only 7 dollar difference between the 2 anyways.
-Thanks.
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 06-10-2009, 06:23 PM   #2
jrwoodchuck's Avatar
Yup!
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 06-10-2009, 06:45 PM   #3
Originally Posted by jrwoodchuck View Post
Yup!
k Thanks for the quick response. Ive heard with v-specs that you want to replace the rod and bearings after break in. Is this neccessary? What will be the benefits? Why do you do this so early? Has anyone else heard of this?
-Thanks
Old 06-10-2009, 06:52 PM   #4
i replace my front bearing only when needed. (ie, a leak)
as for the rod.... if you pre-heat the engine before starting it up during break in, i wouldn't worry about it. but, if you don't pre-heat, yes, replace after break in. these are just my opinions and are not meaning to start a debate.
Doug
TLR 22/M-11
Old 06-10-2009, 06:56 PM   #5
rossoh10's Avatar
yeah around here we use to change the bearings on the 2006 versions..since then the bearings have gotten better...Changing the rod never hurts anytime after break in but is not completely nessecary......unless you have done a lot of cold start up before the p/s has lost its metal pinch
How much fuel to you have through you engine and which version is
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 06-10-2009, 07:07 PM   #6
I just finished with my first gallon through it. Its the 004 version with the 21j carb. I used a heat gun to start my v-spec. I then broke it in with a heavy cloth around the head so the heat would stay inside.
Should I inspect my bearings and rod just to make sure? why would you need to change them after break-in in the first place?
-Thanks again guys
Old 06-10-2009, 07:35 PM   #7
pballer2777's Avatar
Trader Rating: 27 (100%+)
-Thanks again guys
i have a 21c carb on mine. whats the diff?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 06-10-2009, 07:40 PM   #8
BAYCITYSTEVE's Avatar
i think the 21`j came from os xz .28 and the difference is the idle screw is easier to reach ..
BAYCITYSTEVE is offline   Reply With Quote
Old 06-10-2009, 07:42 PM   #9
yeah that idle screw is a pita.
Old 06-10-2009, 07:44 PM   #10
n.e.r.d's Avatar
-Thanks.
you cannot use the Speed rod in the std v-spec.
due to the different location of the oil lube hole..
unless you change your crankshaft to the Speed or Ninja JX version.
Speed rod can be interchanged with the JX rod.
hope this helps!
n.e.r.d is offline   Reply With Quote
Old 06-10-2009, 09:24 PM   #11
-Thanks again guys
I was told to replace the rod with the Speed rod and bearings with TKO after the 3-4 gallon mark just to make sure everything is seated properly and the engine is fully broken in so there isn't alot of stress on the connecting rod.
Speed rod won't fit on v-spec? I've heard of MANY people who got it to work, plus the v-spec has an oiling hole in the crank anyway.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-10-2009, 10:13 PM   #12
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
hope this helps!
WRONG!
Speed rod is perfectly fine in a standard v-spec with standard v-spec crank. Infact it is a very good upgrade. You will be adding a lube hole, but adding one is actually a positive.
As for when to change, I usually change bearings(to TKO ceramics) and rod in my engines anywhere after break-in to the 3 gallon mark. Some engines will hold metal pinch to about 3 gallons. In this case, I change the rod at that mark to minimize the stress on the new rod. Usually OS motors lose thier metal pinch well before the 3 gallon mark. In this case changing the rod after break-in and around the 1 gallon mark is ideal. Bearings, IMO are nessicary for ANY engine. Go ceramic and be done with it. Bearings fail all of the time, especially cheap stock bearings. It's not worth having a rear bearing let go and take out the whole engine. Spend the $40 on a set of TKO ceramics.
You may be able to save some money by going with the ninja JX rod over the speed labeled rod. They are the exact same part, but the JX is several dollars cheaper. I also like to change wrist pin and clips when I change a rod.
http://carolinasrc.com/Webstore/Scri...idproduct=1385
http://carolinasrc.com/Webstore/Scri...idproduct=1384
http://carolinasrc.com/Webstore/Scri...idproduct=5687
http://carolinasrc.com/Webstore/Scri...idproduct=5679
http://carolinasrc.com/Webstore/Scri...dproduct=10454
Those are the parts I would go with.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-10-2009, 10:58 PM   #13
Originally Posted by JAMMINKRAZY View Post
WRONG!
Thanks for all your guys's help. JAMMIN you never cease to amaze me...
Old 06-11-2009, 12:23 AM   #14
n.e.r.d's Avatar
WRONG!
oops, my bad on the OS rod thing..
we learn something new everyday, don't we?
Tamiya Championship Series Neil Rabara Racing Forum 21140 Today 03:49 PM
'08 Tamiya Championship Series @ Trackside Feb.9-10 moshmike Wisconsin & Illinois Racing 212 03-08-2008 09:38 AM
