Old 06-10-2009, 01:33 PM   #1
Default Air in the fuel lines
The motors in my truggy and buggy have been very difficult to tune as of late. I've notice a lot of air bubbles in the lines. I've replaced all of the fuel tubing and the tanks but the problem persists. I'm at a loss to figure out where it's coming from.
The buggy motor is a VSpec and the Truggy is a 427.
Any ideas?
Edit...I also noticed that the silicon gaskets between the two pipe pieces were tearing so I picked up some new ones but have yet to change those.
rav_cherry is offline   Reply With Quote
Old 06-10-2009, 03:00 PM   #2
unsp0ken's Avatar
Trader Rating: 24 (100%+)
are you using any external filters?
unsp0ken is offline   Reply With Quote
Old 06-10-2009, 06:17 PM   #3
+1, check your filters to see if the bubbles are appearing after it. If so, then more than likely the rubber Oring on the filter is no good or it's not down enough. If the air bubbles are before your filter, then you might want to change your tank. It maybe that the tank has a leak in the fuel pick up area closer to the top of the tank so thats where the air is coming from. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-10-2009, 06:40 PM   #4
no filters
Old 06-10-2009, 11:37 PM   #5
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Dont screw the fuel tank screw too tight.......
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 06-10-2009, 11:59 PM   #6
If you've changed the tank, then you might want to try a small zip tie on the fuel line that goes over the nipple. Running out of ideas, but this is another possibility. If the fuel line goes on the nipple easy, then it could be loose, even if it's tight, try a small zip tie on it and see if it gets rid of your problem.
Old 06-11-2009, 03:32 AM   #7
I have been through 6-7 rc8 fuel tanks and it was the pick up. I also believe you have a vibration problem, to check that,remove the tank but keep the fuel lines attached and let it run at idle and look for bubbles.
Joey Platinum is offline   Reply With Quote
Engine leaning out as the fuel goes down ... help please ... Tabushi Nitro Off-Road 16 03-08-2009 07:08 AM
air leak? ruggydriver Nitro Off-Road 7 10-18-2008 12:19 AM
[SYD]-EOI: Savage X SS w/ JRR1 Radio Mloclamau Australia For Sale/Trade 14 07-24-2008 11:35 PM
Problem with starting engine - Pull start Aceboy Electric Off-Road 17 05-02-2006 03:52 AM
Airleak? augerpro Electric Off-Road 14 10-19-2005 05:50 AM
Hobbizone 1:10 TC Gas Race, Titiwangsa KL. 5th June 2004 TPRacing Malaysian R/C Racers 350 06-08-2004 10:12 PM
How do you take care of your engine ?? CS Lo Nitro On-Road 34 04-30-2003 09:22 AM
