Old 06-09-2009, 06:16 PM   #1
cluffy1's Avatar
Arrow HELP
i am having trouble with keeping the screws in the plastic parts of my D8 Buggy is there anything i can do.
cluffy1 is offline   Reply With Quote
Old 06-09-2009, 06:20 PM   #2
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
I use fingernail polish like locktite, it works!
My buddy uses locktite brand of a product called Titen it works good too
OfnaJoe is offline   Reply With Quote
Old 06-09-2009, 06:22 PM   #3
jrwoodchuck's Avatar
i use a drop of thin ca, never backs out.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 06-09-2009, 06:55 PM   #4
What parts are the screws coming out of? Also, how old are they? I have both a D8 and D8T as well as a LSP and haven't had issue with screws coming out.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-09-2009, 10:23 PM   #5
freestylinmotox's Avatar
Ca or locktite has always worked. Nail polish really works for u ha? Might have to try it
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 06-09-2009, 11:41 PM   #6
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
As I know locktite (in blue colour) only work on metal to metal. Correct me if I am wrong. Thanks.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 06-10-2009, 01:53 AM   #7
Gary.Suk's Avatar
Send a message via AIM to Gary.Suk
CA works great.
Yeah blue Loctite won't work on plastic parts.
www.garysuk.blogspot.com
www.socal-drift.com
Gary.Suk is offline   Reply With Quote
Old 06-10-2009, 05:18 AM   #8
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Generally screws are going to stay in the plastic parts without any help. If they won't, that part is probably stripped out or nearly so.
As mentioned you can put a drop of CA, or some other alternatives were listed (CA is the only one I have used) but the RIGHT thing to do is replace the plastic part that the screw won't stay in... and when you do, be careful not to over-tighten the screw and strip the part.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-10-2009, 06:27 PM   #9
cluffy1's Avatar
is about 6 months old.
how do i put the pics on the post.
Old 06-10-2009, 06:43 PM   #10
buy any chance are you having this problem with the left rear and right front lower shock screw? if so, x-ray solved this problem with reverse threaded screws for thoes two points. i'm going to try them in my 2.0, even though they are metric. when i had my 808, they never once backed out. no ca required...
Doug
TLR 22/M-11
Old 06-10-2009, 06:53 PM   #11
& the 808 screws are silver so you wont get them confused with normal screws. Just cant get away from x-ray can you JR
butch man is offline   Reply With Quote
Old 06-10-2009, 07:00 PM   #12
seems to be following me around like a psycho ex-girlfriend.
Doug
TLR 22/M-11
Old 06-10-2009, 08:44 PM   #13
Which screws are the ones you having problems with?
Old 06-11-2009, 06:57 AM   #14
DOMIT's Avatar
I personally like the Kyosho shock PINS with the set screw to secure them. quick and easy to change, no reverse threads to confuse you... I did that on my old Jammin as a mod. I haven't looked into doing it on the Xray truck YET.
Old 06-11-2009, 03:49 PM   #15
cluffy1's Avatar
the problem is with the rear diff housing srews. the D8 has reverse thread shocks srews with it.
Engine decides to lock up on me. Help! sokar Nitro Off-Road 30 08-15-2009 09:56 AM
Run time out of Sirio, HELP?? CHogle Nitro Off-Road 18 08-12-2009 10:02 AM
