Old 06-11-2009, 03:59 PM   #16
Originally Posted by cluffy1 View Post
the problem is with the rear diff housing srews. the D8 has reverse thread shocks srews with it.
Which ones? Is it the ones that come up from under the chassis? Or the ones that hold the hinge pin mounts to the bulkhead? or the ones that hold the chassis braces to the bulkhead, or shock tower, or wing mount? etc?
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-11-2009, 06:28 PM   #17
If its the ones for the rear shock tower lower screws they get pulled out & screw up the threads,once that happens they will never stay in. If its for the long ones that go front to back at bottom of bulk head I believe theres a fix for that too.Read the D8 thread. If its for the ones that go up through the chassis use longer ones & tighten good.
butch man is offline   Reply With Quote
Engine decides to lock up on me. Help! sokar Nitro Off-Road 30 08-15-2009 09:56 AM
Run time out of Sirio, HELP?? CHogle Nitro Off-Road 18 08-12-2009 10:02 AM
