Best Tire for right after they water? >
Old 06-09-2009, 12:02 PM
Default Best Tire for right after they water?
My track sometimes waters in between certain numbers of heats. If your race/qualifier is right after they water, typical race tires (hole shots, city blocks, bow ties, crime fighters) get caked, then powdered with dust to the point where they look like slicks made out of dirt
Is there a good tread pattern that can race semi-wet qualifiers and mains well? I'm guessing one with a less dense pin pattern that wont pick up mud as unsprung weight. Maybe have some inside pins cut out? or even run badlands? haha
It's not fun to slam the throttle to kick off all the mud and cake everyone in the pits as you get fueled.
Let me know what has worked for you guys.
team2zon is offline
Old 06-09-2009, 12:12 PM
wallot's Avatar
XTR crimefighters work most of the time for me
wallot is offline
Old 06-09-2009, 12:15 PM
token's Avatar
That happens alot here with truggies cause the buggy guys cry so much hahahahaha j/k kinda - but no matter what tires you use mud will get ckaed up on your tired for a bit. as the race goes on it will come off mostly. Bow ties are good in the situation because the thread is wide.
token is offline
Old 06-09-2009, 12:30 PM
Trader Rating: 15 (100%+)
The Losi 2.0 kit tires work good for me in those conditions.
ridein04 is offline
Old 06-09-2009, 12:37 PM
Panther K2s
REDNECK7 is offline
Old 06-09-2009, 01:01 PM
tc5 man's Avatar
step pins work great in the wet dirt it does cake up a little but i comes off fast i think they would work the same on 1/8 buggy ,i had them on my gt2 and they were great
tc5 man is offline
Old 06-09-2009, 01:06 PM
Trader Rating: 9 (91%+)
WD-40 On the tires before the run
Theslowguy is offline
Old 06-09-2009, 01:15 PM
Jeff Taylor's Avatar
More HP and you don't have this issue
Jeff Taylor is offline
Old 06-09-2009, 01:32 PM
R/C Tech Elite Member
jkas10's Avatar
Trader Rating: 123 (100%+)
x2 for Bow Ties. They are my tire of choice for tacky tracks. They have more space between the lugs which helps keep mud from packing in the grooves like a crimefighter would.
It sounds like your track is watering TOO much if every racing tire is getting that caked with mud. maybe less water, or wait longer for it to soak in before putting cars on the track........
jkas10 is offline
Old 06-09-2009, 01:48 PM
Trader Rating: 55 (100%+)
I would have to agree also with the bowties.
they have the spread out pattern which is nice and also balloon well on power to help clean a little mud off.
MO
Mo Denton is offline
Old 06-09-2009, 02:35 PM
Trader Rating: 23 (100%+)
Default tires
My tire choice in this situation would by panther k2. The bowties still pack up to much when the track in wet.
Jmnay_83 is offline
Old 06-09-2009, 02:42 PM
imaxx21's Avatar
Holeshots are king at Hot Rod's
imaxx21 is offline
Old 06-09-2009, 02:46 PM
jrwoodchuck's Avatar
i hose down my bow-ties with wd-40 and the dirt won't stick. yes it really works!!!! but it feels like you're on ice for the first couple of warm up laps, it will ware off and the mud won't stick.
jrwoodchuck is offline
Old 06-09-2009, 02:53 PM
pyromania's Avatar
Trader Rating: 18 (100%+)
What other tires work at hot rod? I've tired I-Beams and Calibers, but I think they were making my buggy traction roll. I don't really like how cityblocks work and Holeshots don't last. The only one that have really worked for me are revolvers and XBTs.
pyromania is offline
Old 06-09-2009, 02:56 PM
imaxx21's Avatar
holeshots and gridirons are the best, i can normally get 2 full races out of a set of M3 holeshots
imaxx21 is offline
