RB WS7 III L2G
RB WS7 III L2G
Hi all
What pipe would you recommend for this motor also what glowplug and nitro percentage/shims
Thanks Ben
Thanks Ben
RB2045
n6 and n7 plug dependening on weather
25% fuel with stock shims
30% fuel add 0.01 or whatever the thinnest shim is
ok thanks guys i will give those a try
as for the plugs which one is for hot and which for cold
7= cold ->hot weather , 6=medium - universal
i have been running the OS 2060 pipe and header with mine
6mm venturi
.1 head shim
30% fuel
there isn't a car that catches or keeps up with me down the straight at our local track
when tuned right it gives me a 9.5 minute runtime on our track which is very good because its a wide open track and your always on full throttle
6mm venturi
.1 head shim
30% fuel
