Old 06-07-2009, 11:14 PM   #1
rcboxer's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to rcboxer
Default losing radio communication
Hello, This weekend I had problems with my radio losing communication with my 8t2.0. Everything worked great last time i used it. I am having trouble figuring out what the problem is so I thought I would ask you guys for some things to look for to help me out. I use lipo batteries in both me futaba 3pk and in my truck, and they were charged. I also tried changing out the receiver with a different one but still had the problem. I am using the 3pk with the spektrum receiver system. During the race it would lose communication like 2 or 3 times a lap, both throttle and steering. Any ideas? thanks, Ryan
rcboxer is offline   Reply With Quote
Old 06-07-2009, 11:15 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
did you try re-binding it?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 06-07-2009, 11:21 PM   #3
rcboxer's Avatar
Ya tried that too. I tried it in two different receivers and same result. It seemed to get worse as the race went on. I checked my battery voltage after the race and they were good. Could a voltage regulator cause any problems like that? thanks
Old 06-07-2009, 11:23 PM   #4
imaxx21's Avatar
maybe, sounds like the module
-Crash
Old 06-08-2009, 08:07 AM   #5
Integra's Avatar
If your running spectrum Rx....and potentially have good enough servo's....you could yank that regulator out with out fear.....ALot of guys are running unregulated these days on all sorts of servo's....from cheepo 30$ one's to 120$ hitec's that are rated for 8.4v.....try with a Not fully charged pack and take it out for a test run.
Old 06-08-2009, 08:18 AM   #6
scwrod's Avatar
check all wire connections. Could be a connection briefly loosing contact or even the switch itself.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 06-08-2009, 08:42 AM   #7
Trader Rating: 26 (100%+)
check the antenna wire in the module it self it could be brefily making contact.
m henry is offline   Reply With Quote
Old 06-08-2009, 08:56 AM   #8
Wenbiao's Avatar
Default KO EX10 Helios 2.4 module and RX
any comments on the above ?
Wenbiao is offline   Reply With Quote
Old 06-08-2009, 10:21 AM   #9
rcboxer's Avatar
thanks guys for all the replies I did notice a little nick in the wire coming from the regulator but the metal part of the wire looks okay. I was thinking about the switch, unfortunatly the switch is part of the losi regulator. INtegra, if I dont use a regulator will the transponder be okay? My servos are hitecs, one is a 985 analog and the other is a 5995 digital. I checked the antenna wire and it looks good too. thanks again for your replies
Old 06-08-2009, 10:24 AM   #10
rcboxer's Avatar
You know i didnt actually check the wires in the power wire its self, good idea I will check that when I get home. thanks
Old 06-08-2009, 10:37 AM   #11
baruke1's Avatar
Trader Rating: 17 (95%+)
Put a regular hump pack in and forget the regulator and I bet you will be problem free.
baruke1 is offline   Reply With Quote
Old 06-08-2009, 11:05 AM   #12
Integra's Avatar
the transponder can handle it no problem's so can the 5955...but the analog 985 might be questionable...your call...if it pop's its an excuse to upgrade.
Old 06-08-2009, 11:16 AM   #13
rcboxer's Avatar
LOL very true. that thing has lasted me like 2 years though, I am almost attached to it That would give me a good reason to throw in my jr9100 in there.
Old 06-08-2009, 11:39 AM   #14
Trader Rating: 47 (100%+)
Throw that P.O.S. Losi regulator away. Three out of
four that we bought gave nothing but problems. We
tried them in different cars with different radio systems
and they were the cause of all the glitching problems
we were having. If you think you need to use a regulator,
the five or seven amp Protech regulators work good.
rageworks is offline   Reply With Quote
Old 06-08-2009, 11:56 AM   #15
Frank L's Avatar
Trader Rating: 148 (100%+)
Is the antenna from the receiver bent or broken? And make sure the antenna is all the way up. I had that same problem in my 8t 2.0 with a spectrum DX3R and once I put the antenna all the way up in the tube the problem went away. I even left it inside the body just up in the tube and it was fine. The problem only happened at 1 track.
