Old 06-07-2009, 05:36 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Engine run time
I want to be able to know when to come in for fuel on a race. How can i test this? Should i just fill up the gas tank and let it sit there in idle or should i actually drive it around? Im not at a track right now so i have to do this in the driveway.
Let me know thanks
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 06-07-2009, 05:39 PM   #2
gkn0315's Avatar
Trader Rating: 126 (100%+)
Its best to do that at the track but you can get a good idea of how much run time you would get by running it up and down the drive way hope it helps im getting 12 min on my os speed with a jp4 pipe
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 06-07-2009, 05:43 PM   #3
Let me know thanks
To guage your fuel/run time you need to running at race pace on the track. If you are going to a race for the first time, you could use your qualifier to help determine how long you can go before you come in for pits. Keep in mind that the more you crash, the less fuel you'll use in a qualifier cause your aren't pushing the gas when you are being marshalled. I used my qualifiers to see how far I can go in the main. If after our 8 minute qualifier I have a 1/4 to 1/8 tank, then I'll go 8 1/2 to 9 minutes after the start then 8 minutes each tank for the rest of the race. You'll need to give some account for air bubbles in the tank when they are refueling you, so that's why I go little shorter after the top off before the race. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-07-2009, 05:44 PM   #4
Dalepad's Avatar
It helps if you and a buddy go to the track and try it out but the driveway will give you a rought idea. Take and run around the driveway and try to simulate running on the track. I take and time how long it takes to run out of fuel and sudtrack a minute or so what ever you feel and have your pit guy time you with a stop watch for your pit times. Hope this helps
Dalepad is offline   Reply With Quote
JP engines jasoncsc Onroad Nitro Engine Zone 1160 05-10-2017 07:19 AM
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
Truggy Engine NitroAmmo Nitro Off-Road 29 08-13-2009 05:01 PM
Run time out of Sirio, HELP?? CHogle Nitro Off-Road 18 08-12-2009 10:02 AM
ROSE CUP JUNE 2-3 JANTZEN BEACH Mike Ellis Northwest Racers 112 06-08-2007 01:20 PM
Engine Wars Thread EVOLUTION Nitro On-Road 697 12-15-2003 10:18 AM
