starter boxes
starter boxes
ok, i now this has been said 1000000 times but once more wont hurt cause i have a little twist on my question
i have 3 losi starter boxes. i love them because i race truggy and bugggy and i like that you can change the box to fit both in two seconds. two of these boxes has upgraded wire and i put integy 55t motors in one of them and they burnt out. my dad bought a brand new box for some reason and put upgraded wire in that and the stock motors went out yesterday.
i was thinking about the ofna truggy box, people have told me its bullet proof. but how fast can i move it from truggy to buggy? all losi btw.
and will i need to do anything to the box like wire or anything?
or if anyone has a fix for the losi box that would be great. i would like to stick with this if anyone has a motor that will last in that
http://carolinasrc.com/Webstore/Scri...idproduct=4845
The fix for the losi box is to throw it in the garbage. Get yourself an ofna truggy box. Best box in the business. It will turn over the tightest motors very easily. I run mine with 12v gel cell's and stock wiring and it is still a beast. There are mods that can be done so you can use both buggy and truggy on one box, but myself, I just use 2 boxes. I was planning/have been meaning to upgrade the wiring to deans wet nodle and deans connectors, but never got the chance. They work so well stock, I may never do the upgrade.
I skipped the Deans connectors all together and just soldered my Wet noodles directly to the motors/switch..I then soldered the Clips for the gel cell to the other side..The less connectors the better, and you can still remove the battery for charging....
Doug..there is no question the Ofna Truggy box is the best box on the Market..It is not easy to make it fit both bug and trug though, Unless you can find top plates that are easily interchanged
I have the Ofna also and love it. I took all the pins off, have buggy and truggy. I set it on and line up wheel to slot by looking down by fly wheel. It took alittle practice, but it becoome reflex after short time and now I dont even miss the pins and am pretty fast at it.
I switched from the losi box to the ofna truggy box and I love it. The truggy box has broken in a GRP .28 and an OS speed recently without ever getting stuck. I dod not even one time have to unstick the fly wheel like I would have had to to many many times with the losi box. I also installed deans wet noodle and a 4S lipo. This box really will start anything. I took the hardware off the top of the losi box and with the help of a dremel I installed it on the ofna truggy box. Dont let me fool you it took several hours and several bits. But now that its all done the ofna box will start either the truggy or buggy with just a slide and twist just like the losi box did. I fellow racer asked me to do a write up on it a little while ago. Heres the link check it out.
OFNA BOX TO LOSI BOX CONVERSION
There is also this type of starter box mod. This one would be so much easier. I wish I had seen this before I did the mod above.
STARTER BOX MOD
STARTER BOX MOD
Mine isn't as pimped out as Frank L's but it works tons better and I never have to worry again. Plus the box is useable with buggy and truggy. Only thing I did was put the Ofna Truggy start internals into the Losi box. I lined up the Ofna parts inside the Losi box and then dremeled some slots for the screws.
Well this is the entire Truggy Start setup put into the Losi box. So I didn't have to move the motors to the Losi motor mounts or anything. It's hard to see in the enlarged pictures of the motor, but the top motor in the picture is "slightly" pushing out on the side of box. So it's not like it's a direct fit. But they do fit with some dremel work.
oH I know the boys are gonna love this......WELL
After 1.5 year's my stock motor's and lipo combo gave up.....Not only did i lose a pair of motor's to MY box....but buddy burnt out my spare 4 cell in his losi box......Granted he's never been that good with starter boxes...but his BN GRP he decided to Not pre heat and make the box do all the work....well he'll be workin extra hard this week to pay me off what he owe's.
So the question is....which route do i go now.
I put the Traxxas 23t motors in my starter box, it worked flawlessly, I'd expect a pretty long life with those traxxas motors. They key is knowing when your car is or isn't going to start. So often I see people just hammering away on their starter box. Also having the height set correctly is key to long motor life.
If the flywheel contacts the rubber wheel BEFORE the motors spin then the load on the motors is very heavy, if they're spinning at full speed before contact the engine will fire right up and the motors will last a very long time. I think most people ignore how important the height adjustment is.
