Old 06-05-2009, 11:41 AM   #1
Questions?? How many head shims on OS V-spec .21
Hi,
What is the default/stock head shim amount? Is it 0.2mm (one thick alu shim)? I got my engine new but not in a box and so I don't know if the extra shim there already one too many. At the moment I have 0.2mm alu + 0.1mm copper + 0.1mm copper. Seems a lot to me. The engine is now broken in so its time to get the maximum performance out if it.
I'm in a hurry and can't find an answer from anywhere. Thank you for quick answers. Couldn't find it from search or the user manual.
lauri is offline   Reply With Quote
Old 06-05-2009, 11:46 AM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Use one aluminum and one copper one for sure. If the motor is to much to handle throw the extra copper shim in.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 06-05-2009, 11:50 AM   #3
Wow man, this was fast
Can someone tell me if this means 0.3mm? Alu shim is 0.2mm and copper is 0.1mm?
Is there a reason for the thicker alu shim? Why don't they just use 3x copper shims in total?
Old 06-05-2009, 11:53 AM   #4
hambone's Avatar
Originally Posted by lauri View Post
Hi,
The xtra .004 shim (i'm american) is recommended by OS if you run 30% nitro. Not needed at all.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 06-05-2009, 05:39 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
I have an os speed and I run the stck shims 1 alum and 1 copper with 30%. No problems at all smooth as silk. The extra shim will decrease compression and tone the engine down. It's not necessary.
Old 06-06-2009, 12:58 PM   #6
Thank you for the answers. The engine worked a lot nicer when it had correct compression It worked nice throughout the 45-min a-main, only my mistakes dropped me to 3rd place, not better today
2 races, 1 training, 1 liter (quart) of braking in and the pinch is starting to disappear and the engine is starting to be economical. T-2060 really works nice on the V-spec. Nice powerband with really nice economy
