Old 06-04-2009, 07:58 PM   #1
Default d8t
my bro bought the d8t and hinge pins keep come out need help.
lovemy2.0 is offline   Reply With Quote
Old 06-04-2009, 08:03 PM   #2
tc5 man's Avatar
do the cheap way put a dab of shoe goo where the whole is that holds the hinge pin it wont go anywhere just let it dry for 24 hours . how do like that d8t hows it handle and jump etc.
Old 06-04-2009, 08:05 PM   #3
fatdaddy's Avatar
are the inner or outer pins are falling out and how? are there screws loose? or is something breaking causing this?
also, the offical D8T thread is here: Hot Bodies D8 Truggy
lots of good information and discussion about the truggy there
fatdaddy is offline   Reply With Quote
Old 06-04-2009, 08:28 PM   #4
Trader Rating: 125 (100%+)
You need to put the Kingheadz suspension block from the Lightning series. It calls for you to drill two 4mm holes on the chassis to lock this block in place, preventing the hingepins from ripping out of the bulkhead. My friend Gotspeed2000 told me about this upgrade and it becomes bullet proof! Or you could use M2C captured hingepins. It has nuts on both sides preventing the suspension blocks from separating. Check out the other thread mentioned. Alot of great info there.
Neesh is offline   Reply With Quote
Old 06-07-2009, 05:49 PM   #5
Default d8t
inner hinge pins and only the front one and when the pins come out the bend..
Old 06-07-2009, 06:00 PM   #6
CWILK's Avatar
The front diff case is broken. He needs a new diff case and the m2c hinge pins.
D8T TE (TNS) 21XZ-B Speed Spec II
D815 Speed B2101 Ty Tessmann Edition
PM Hobby Craft Team Driver
www.pmhobbycraft.ca
AKA/www.raceaka.com
CWILK is offline   Reply With Quote
Old 06-07-2009, 06:18 PM   #7
If you are breaking the bulkhead, especially the side of the bulkhead that the input gear is on then you should consider the King headz upgrade I've done. Using the King rear lower mount in the 3 degree model, then drill the chassis to use the 4mm screws from under the chassis. Jesse Robbers did this, but used the stock rear mount and 3mm screws to help keep the hinge pin mount from pulling on or damaging the bulkhead. Look a few pages back and you'll pictures of what he did and what I did when I mounted the King Headz mount. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-18-2009, 07:31 PM   #8
Default d8t
diff case are not broken the screw keep pulling out. so i need to find a way to fix that before i buy a new diff case so i dosnt happen agian. and thanks for all the help with this.
lovemy2.0
Old 06-19-2009, 12:28 AM   #9
lovemy2.0
If the holes are ovaling, then do what I said about filling the extra holes with thin layers of CA. Make sure you apply thin layers at a time.
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Impulse-r/c Clutch Shoe Review Steebo Nitro Off-Road 73 03-31-2010 09:08 PM
Turf City 1/8 Off Road Buggy / Truggy and EP Truggy Race, 16th Aug 2009. leng Singapore R/C Racers 76 10-08-2009 09:36 PM
Hotbodies D8T *Brand New* UnknownFive R/C Items: For Sale/Trade 17 08-24-2009 07:54 PM
Turf city 1/8 Off Road Buggy FEMCA Qualifying Round 2 leng Singapore R/C Racers 55 05-27-2009 04:53 PM
