Old 06-03-2009, 05:33 PM   #1
Default front bearing
How difficult is it to change the front bearing in a trx 3.3? It has been running wierd and I noticed that the front bearing is dripping, so I assume it has a air leak. Also, on the Traxxas forum, they said that Traxxas recommends not sealing their motors, should I do it anyway?
cassidy is offline   Reply With Quote
Old 06-03-2009, 09:10 PM   #2
infernus1986's Avatar
If is only dripping its fine, now if you have residue all over the chassis around the clutch and front of the engine there's a problem.
The trx engines are made to have a small bit of oil leak out of the front bearing, theres actually an oil port for the front bearing drilled through the case near the carb.
Any way to replace it you have to completely dissemble the engine and heat crankcase up to 250-300* from there you should be able to push the bearing out with a chock of wood and a hammer repeat the process to get it back in.
infernus1986 is offline   Reply With Quote
Old 06-04-2009, 02:47 AM   #3
Rampokker's Avatar
Before going through all the hassle of replacing the bearing, I would just buy a crankcase with bearings of e-bay. There are a few "chop shops" that strip new engines and sell them off. Like this one here.
And in regards to sealing the engine, I've never had the need to seal any of my traxxas engines. I just installed new o-rings and never had any issues. There are plenty of other people who sealed their engines, and it worked for them. So if it would make you feel better, seal the sucker up.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Corally Owners Club v1.* WillS Electric On-Road 1371 05-06-2003 11:53 AM
Barracuda (last one in my garage) Diva R/C Items: For Sale/Trade 21 12-14-2002 06:44 PM
