Old 06-02-2009, 08:34 PM   #1
Default need some shock advice
i took my shocks off today to fill them with some new oil for the first time,(this is a used rc8 buggy)when i took the cap off i noticed the bladder that sits just above the oil had the bottom cut out of it. the only part remaining of the bladder was the part that goes up into the threads of the cap.all four were the same.is this a trick or some kind of a mod,i dont know,the shocks did not leak. i filled them with oil and recaped them than tested them ,when i reopend them there was a ton of air bubbles,is that from the bladder being gone or did i do something wrong,is that normal.help a newbee out thanks
bigguyrc8 is offline   Reply With Quote
Old 06-02-2009, 09:01 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Your shocks need bladders so order some new ones right away, the bladders are what help seal up the shocks and also that is where your rebound comes from. The shock oil pushes up the bladder and the bladder repels the oil and pushes the piston back down, without bladders you will get leaky shocks, lots of air bubbles and lots of bouncing...Air bad...Bladders good
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-03-2009, 12:27 AM   #3
losi_racer's Avatar
Trader Rating: 25 (100%+)
do you ever do any kind of work jaz? yous always telling us you cant come out due to work but all i see is you on here
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-03-2009, 01:59 AM   #4
That was a normal mod when the rc8 came out.they had severe shock problems & one factory recomended cure was to cut out the bladder & turn them into emulsion shocks like the old 1/10 shocks.If you liked them that way just rebuild them that way.If you have plastic shock caps see if the old owner drilled a hole & put a screw in them for bleeding,thats another factory rec fix.Also pull off the shock boots & see if theres any thing over the shaft at the bottom like a shock piston & fuel tube,also a factory rec fix.
I cant seem to find the instructions & part# for what they tried on the old shocks anymore but search the AE forum under rc8 & you'll see the info in there.Basicly fill to 2mm bolow top,install cap with screw removed,push shock shaft up all the way,install screw. Or buy big bore shocks & what ever # shock tower their up to.
If you need I'll try & email the instructions but I cant figure out how to post a pdf here.
butch man is offline   Reply With Quote
Old 06-03-2009, 08:40 AM   #5
Jaz240's Avatar
I am off on tuesdays..and when I am at work I sit in front of a computer all day
Old 06-03-2009, 01:28 PM   #6
losi_racer's Avatar
ill buy your work sounds like the greatest job in the world. hell you can even test drive your sofas ha ha
Old 06-03-2009, 01:48 PM   #7
Jaz240's Avatar
You wouldn't want my job in this economy Doug..I used to be rich and I had 3 days a week off! All the money is gone (to keep the store open) and now I work 6 days a week..Hopefully I can get my life and my money back some day
Old 06-03-2009, 01:58 PM   #8
losi_racer's Avatar
true,i like sitting on my butt tellin people what to do and i make the same if were busy or not. and i have sat off ....... ok you keep your job ill keep mine lol
Tamiya mini cooper sipaboy Electric On-Road 29535 Yesterday 05:06 PM
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 09:01 PM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Which Buggy 1/8 nitro to Choose????? Paulybehaved Electric Off-Road 24 01-03-2007 07:08 AM
