Old 06-03-2009, 11:53 AM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by butch man View Post
I do the same as Houston only different, Around the HS needle housing across front of carb & around ball end pull.
Sharp corners on carb dont seem to cut those things & it takes nitro a month or more to turn them yellow & loose tention,brake cleaner dont melt them either.
I use 1 band but have seen people use up to 3,not sure why but what ever makes you feel good.
that was a new engine and was just showing how to install one butch .
hope it helps ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-03-2009, 12:10 PM   #17
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
This is what I use, it will supply me for years! Size 10, cant beat the price.
http://www.mcmaster.com/#12205t51/=25qlr2
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 06-03-2009, 12:13 PM   #18
I use 3-4 at a time too.
Old 06-03-2009, 12:16 PM   #19
M_Flores's Avatar
Trader Rating: 15 (100%+)
Originally Posted by houston View Post
use goodys ouchless clear bands .
available in the hair care aisle
they are the best throttle return spring i have ever used , i include them on most of my engines .
would you like a pic ?
yes it works with losi too
How long until you have to replace the band?
M_Flores is offline   Reply With Quote
Old 06-03-2009, 12:18 PM   #20
Trader Rating: 40 (100%+)
Generally What I do with all of my cars is on the servo arm atach the spring then to a part of the car itself. generally there is a mechanical advantage when the servo arm is longer than needed for the throttle location and you can use the more outside holes for the spring.
jdeadman is offline   Reply With Quote
Old 06-03-2009, 12:20 PM   #21
houston's Avatar
i have had some last over four gallons of running
Old 06-03-2009, 12:22 PM   #22
houston's Avatar
and if the ball cup comes off the carb
Old 06-06-2009, 10:45 AM   #23
Good point Houston !
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 05-04-2012, 12:01 PM   #24
houston's Avatar
and from the archives!!
Old 05-04-2012, 09:52 PM   #25
I have used silicone bands and they don't last a tank. What am I doing wrong?
Mark _australia is offline   Reply With Quote
Old 05-04-2012, 10:47 PM   #26
Houston
So does the Band get wrapped around the top of the uni ball, then around the hsn? It's a little hard to see. I'm going shopping for some hair products tomorrow!
BlockHed is offline   Reply With Quote
Old 05-04-2012, 10:59 PM   #27
houston's Avatar
Originally Posted by BlockHed View Post
Houston
click on pic and blow it up , shows pretty clear bro
iit depends on where your ball is , i put these bands on all my "tuned" engines for my guys
Old 05-04-2012, 10:59 PM   #28
houston's Avatar
my guess is you are using a heat gun
Old 05-04-2012, 11:10 PM   #29
Gotcha, looks easy enough. Easy, inexpensive, quick fix, can't ask for much more
Thanks for the help
Old 05-05-2012, 01:38 AM   #30
JoePit's Avatar
2 cars at the track tonight had power failures, 1 went poof almost instantly, the other I managed to save after a 150' run across the track with my trusty rag in hand. Both those guys were not running any kind of a return spring. After reading this thread I stopped at Walmart today and picked up those hair ties and they work like a charm. Not that I had any issues with my car, but after seeing what happened tonight it was a eye opener. The rag I walk around with was also another idea I picked up from Monty.
Thanx for sharing Monty
Joe Pitruzzello AKA Joe Pit
Losi 8ight B 3.0|Losi 8ight T 3.0|Losi SCT Nitro|Radiopost|Red Rock Hobbies
www.redrockhobbies.com
Fear Farm Raceway
JoePit is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
mugen seiki mrx3. need help with radio! vuanhquoc Nitro On-Road 13 02-19-2009 12:48 PM
Radio Contro Racers Edmonton Off Road Racing dabalaberda Canadian R/C Scene 1605 10-23-2003 08:41 PM
