Old 06-02-2009, 02:46 PM   #1
TRXRustler33's Avatar
Default Duratrax Evader ST
I have a Evader and i cant keep it running, i just wanted to know how to tune the motor.
Team Terribles
Suzuki RM125
TRXRustler33 is offline   Reply With Quote
Old 06-04-2009, 12:41 PM   #2
whats your motor doing,
have you checked,
glow plug
fuel lines
exhaust gaskets. ( if they're bad, you'll run excessively HOT, no power and richening up wont fix it.)
and when all else fails try resetting your needles back to factory settings.
one last thing. how old is your fuel. and where do you store it.
If it's in the garage on the floor. theres your problem.
rc_racer1 is offline   Reply With Quote
Old 06-04-2009, 01:20 PM   #3
I start it normally and i cant let off the throttle or it will shut off and when it does shut off it wont start until it cools down and i tried setting it to the factory settings please help.
Team Terribles
Suzuki RM125
Old 06-05-2009, 11:21 AM   #4
ok, have you checked the minimum opening inside your carb. if it's closed too much it wont stay running.
easy way to set it, turn it all the way out so the carb is closed. then turn the screw 1 turn. your opening should be about 1/64 of an inch. not sure what the metric equivelent is but it's close to where it should be.
Old 06-05-2009, 12:43 PM   #5
I did
Team Terribles
Suzuki RM125
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 01:27 AM
FS: Duratrax Nitro Evader ST Aluminium suspension plate. Sammus R/C Items: For Sale/Trade 10 08-23-2008 06:12 AM
Losi XxxT-Cr & Duratrax Evader St Roller xsxracing R/C Items: For Sale/Trade 38 01-20-2008 12:56 AM
Which ESC is better? Syber Serulean Electric Off-Road 19 09-23-2007 08:56 AM
