Old 06-02-2009, 08:21 AM   #1
Waters's Avatar
Default OS speed sleeve & piston in V-Spec
Does any one know if the OS speed sleeve and piston would work in a OS V-Spec. Thanks...
Losi 8b 2.0, Werks B5 2057, Losi 8bE 1.0 2200kv 3s 7-12 ounces, T4.1, B4.1,
Waters is offline   Reply With Quote
Old 06-02-2009, 08:25 AM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Yes you are good to go!
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 06-02-2009, 09:34 AM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
yup they are a direct fit.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-02-2009, 10:55 AM   #4
yes and make sure to get a speed rod as well
go really fast and turn left....
Robert.Hull is offline   Reply With Quote
Old 06-02-2009, 11:04 AM   #5
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
You only need the Speed connecting rod when using a Speed crank due to the difference in the oiling hole location. Using a Speed piston and sleeve doesn't require the conn rod.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 06-02-2009, 11:06 AM   #6
Tech Legend
Wild Cherry's Avatar
I see posts like this all the time ..
The stock V-spec crank is not like the speed version , no need for a extra hole on the con rod as the stock part has a hole inside the crank pin journal already...
So whats the need for two holes ?
If you do use the speed rod, should`nt you also mate it with the speed crank as well ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-02-2009, 11:12 AM   #7
imaxx21's Avatar
Send a message via AIM to imaxx21
2 holes are better than one...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 06-02-2009, 11:46 AM   #8
Waters's Avatar
Thanks again...
Old 06-02-2009, 12:01 PM   #9
the speed rod is machined better and it doesn't wear as easy as the stock v-spec rod
and there is nothing wrong with more oil getting on the shaft
Old 06-02-2009, 12:11 PM   #10
Agreed. It is a good upgrade, but not nessicary for this application. If you are buying a rod, go with the speed one. If you already have a normal v-spec rod, it will work fine.
-Koby Kubrin-
Old 06-02-2009, 12:38 PM   #11
l3asher's Avatar
I was told the speed rod is heavier. Is this true?
l3asher is offline   Reply With Quote
Old 06-02-2009, 12:51 PM   #12
Not sure really. It's possible, but I doubt it.
-Koby Kubrin-
Old 06-02-2009, 01:47 PM   #13
Trader Rating: 32 (100%+)
Tower has the p/s/r for 179.. p/s for 149..
pay the xtra 30 bucks and get the set, while you're at it use the coupon code to get 25 bucks off.
devilchrist is offline   Reply With Quote
Old 06-02-2009, 01:55 PM   #14
losi_racer's Avatar
Trader Rating: 25 (100%+)
i have the ninja p/s in mine. i plan on puttin the speed rod in about a gallon mark. so maybe a month
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-02-2009, 03:01 PM   #15
cary's Avatar
Trader Rating: 67 (100%+)
i weighted the two rods on a digital scale not the best one
only goes in one gram increments . they are both
3 grams ea but when i put them both on it comes up
7 grams need a better scale
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
