Old 05-29-2009, 10:30 AM   #1
Default LOSI 2.O QUICK CHANGE MOTOR MOUNT V-SPEC
Ok I have tried to get a v-spec on a quick change motor mount for a Customer of mine and it just will not go on there right am I missing something?
PUDDIN is offline   Reply With Quote
Old 05-29-2009, 10:55 AM   #2
pballer2777's Avatar
Trader Rating: 27 (100%+)
i got mine on a kingheadz motor with no problem. whats the problem u r having.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 05-29-2009, 10:57 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 on the king headz. An OS speed mounted no prob.
Old 05-29-2009, 11:06 AM   #4
pyromania's Avatar
Trader Rating: 18 (100%+)
I run a quick change on my v-specs w/ no problems. What is happening that it won't go in?
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 05-29-2009, 11:22 AM   #5
I can not get one hole to line up...you can see where the screw is hitting to the right of the hole...I have tried everything...even the motor mounts where are to push down on to the pins.
Old 05-29-2009, 11:37 AM   #6
Frank L's Avatar
Try flipping one of the mounting plates around. What quick change engine mount are you using?
Old 05-29-2009, 12:09 PM   #7
pyromania's Avatar
Lets see if I can try and explain it:
When you put the screws in, don't tighten them all the way. Leave 3 of them loose when trying to put in the last one. Once all screws thread in, you can tighten down.
Jesse Carrillo
Team Driver For:
Old 05-29-2009, 12:26 PM   #8
Integra's Avatar
X2...if you lock the top blocks onto the block Not Mounted to the base the pins will not line up.
Old 05-29-2009, 01:37 PM   #9
aaron joy's Avatar
Trader Rating: 16 (94%+)
Try chamfering the inside edge of the top blocks a little where they might be touching the engine. I had to do this for my RB's because the upper mounts were binding on the lower posts making it a not so quick change mount.
aaron joy is offline   Reply With Quote
Old 05-29-2009, 02:32 PM   #10
Losi quick change engine mount guide
#4 apply an engine top mount to each side of engine with arrows pointing towards the clutch. ONLY THREAD EACH SCREW IN A FEW TURNS.
#5 place engine assembly on the base mount and fully tighten the screws installed in the previous step, this will ensure the locating pins are correctly aligned.
#6 attach the top mount to the base with the 5-40x1/2 cap head screws; apply loctite to the screw heads.
#7 place the engine assembly into the chassis and reinstall the engine and pipe mounting screws. Set gear mesh.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-29-2009, 03:08 PM   #11
malcnz's Avatar
yip the key is not to tighten them down until they are all threaded in
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
