Old 05-28-2009, 05:58 PM   #31
Originally Posted by dreaux View Post
after it thaws could you repeat the process to keep pushing the pipe out?? I have a pretty big dent on it.
Yep! I had an RB 2020 that was crushed almost halfway in. Looks / works great now!
-Howard
pur3evil is offline   Reply With Quote
Old 06-01-2009, 02:35 PM   #32
unsp0ken's Avatar
Trader Rating: 24 (100%+)
so after cooking this stuff in antifreeze, what do you guys use to rinse the stuff out?
unsp0ken is offline   Reply With Quote
Old 06-01-2009, 02:44 PM   #33
houston's Avatar
Trader Rating: 91 (100%+)
shake it out with some water and an air compressor
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-01-2009, 02:52 PM   #34
Davidka's Avatar
Trader Rating: 75 (100%+)
Be wary of the freezing trick, if you have a big dent and you freeze a few cycles to get it out, it's possible the the divergent cone (the one inside) to become disconnected from the wall of the pipe. If that moves around in the pipe while you're running the effect can range from bad tuning problems to engine damage if you attempt to "tune the problem away" for too long.
