Old 05-26-2009, 07:54 PM   #1
Default Breaking in my Nitro Sport...
I'm basically just running 3/4 throttle the whole way for 2-3 min intervals. Then letting it cool off. Then doing it all over again. Is this the correct way?
eighty2 is offline   Reply With Quote
Old 05-26-2009, 07:57 PM   #2
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
To heat cycle your engine...
Prime the engine with some fuel so it is lubricated when you go to start it. (basically, remove the glowplug and drop a little in the piston, and poor a little down the carb)
Start the engine with the factory settings and make sure it will idle. (sometimes you have to lean it out a little since factory settings are usually pretty rich)
Take the car and put it on the ground, begin running large circles/figure eights. Blipping the throttle but never opening it more than halfway. Keep an eye on engine temps. Get the engines temps up to 200 degrees as quickly as possible. You most likely will have to lean the engine some or wrap some foil around the head. IT IS VERY IMPORTANT TO GET THE TEMPS UP TO 200. If you break it in at a lower temp, you will be damaging the engine. Keep the engine tuned rich on the bottom for good lubrication... adjust the high speed needle to help bring the temps up.
Run the car for 2 minutes, then pull it in and shut it down. Make sure to return the piston to bottom dead center of the stroke. Allow the engine to cool.
Once the engine cools (around 90 degrees), start it back up and do another 2 minute cycle. Make sure the temps are around 200-210 degrees. Again, blipping the throttle and not opening it up all the way.
Again... pull it in after two minutes and allow to cool. Be sure to move the piston to the bottom of the stroke.
Now you can increase the run times up to three minutes. Do this for two more 3 minute cycles, keeping temps between 200-210 and cooling between cycles.
For the final two cycles, increase the run time to 5 minutes.
Now the engine should be ready for a race tune (you'll probably have to richen the high speed needle back up since this is what you used to lean the engine for break in). Keep it rich for the first few tanks and make sure the engine is making good smoke.
^Compliments of Al Jones^
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 05-26-2009, 08:06 PM   #3
Ok. Other than buying an expensive thermometer, how do I tell the temp?
Old 05-26-2009, 08:10 PM   #4
Spit on the cooling head, if it sizzles but doesn't jump you are good, but if it sits there you are too cool.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-26-2009, 08:13 PM   #5
Beautiful. I touched it and it was hot to the touch, but not hot enough to make me pull my hand away right when my hand made contact. I guess you could say it was luke warm.
Old 05-26-2009, 09:43 PM   #6
$25 is alot? PE-1 tempgun.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 05-27-2009, 05:21 AM   #7
Oh. I didn't know they were that cheap. Shoulda done my research.
rhonda skelton Redfox03 Nitro Off-Road 210 07-24-2009 09:15 PM
Future of Nitro Off Road Amp'd Racing Nitro Off-Road 15 08-20-2008 01:31 AM
VORTEC Nitro - your thoughts? Sp Racer Australian Racing 594 04-02-2008 02:14 AM
It's time for race tracks&directors to step up Juan Aveytia Electric On-Road 19 11-26-2006 07:09 AM
I dont know what to buy... rexzilla_03 Electric Off-Road 58 10-13-2004 05:41 AM
