Old 05-26-2009, 02:33 PM   #1
vladconnery's Avatar
Trader Rating: 35 (100%+)
Default PICCO HELP
I have built and torn down quite a few engines.
This one has me stumped. I built a Picco EVO 2 from new parts.
The issue I am having is the engine will turn over for a short period. If I blow through pressure line and send fuel into carb. However it will not coninue to send fuel into carb. I thought it was a clog pressure nipple. I removed pip cleaned and tried a different pipe still no luck. It will send fuel through lines if I hold stinger and bump engine on the box. The engine is sealed Lucky 7 on back plate, pinch bolt, hsn and carb neck.
I have noticed fuel around the front bearing. The bearings were already mounted in the case so I can't vouch for them. I can replace with some new and even TKO's if necessary. That was my plan anyway after I got a gallon through.
However would the bearing leaking cause enough pressure loss to prevent fuel from pumping into carb?
Thanks in advance for you ideas, suggestions and knowledge!!!
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 05-26-2009, 03:50 PM   #2
Default re
just a thought,remove the hs needle see if sealant got down on the spray barand plugged the hole to the ls needle,or if you have one try a different carby
toofless is offline   Reply With Quote
Old 05-26-2009, 04:15 PM   #3
I will do that however Lucky 7 is a crack filler. I have always used it after the engine is assembled. NEVER use Lucky 7 as a gasket maker it is not Nitro proof. As a matter of fact I don't really suggest using any sealant as a gasket maker or applying any sealant where it can be exposed to nitro. Most of the sealants on the market are NOT nitro proof. Better safe than sorry!!!
KO PROPO EURUS
Old 05-27-2009, 03:26 AM   #4
Still looking for some ideas.
KO PROPO EURUS
Old 05-27-2009, 09:59 AM   #5
Focusprinting's Avatar
Maybe you have a crack in your tank or a crack in the internal pickup line in the tank. If it is a crack in the internal pickup line then the tank will pass the pressure test but may still cause the problems that you are experiencing. I would try a new tank.
www.focusprinting.com
Focusprinting is offline   Reply With Quote
Old 05-27-2009, 10:02 AM   #6
if the front bearing leaks like hell then it would prevent the motor from building any pressure as it would all go through the front bearing.
Try the simple things first.
Replace your tank, if that doesn't solve the problem then replace your front bearing with one from TKO.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 05-27-2009, 12:55 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
+1, My front bearing was sucking air so bad, that It would not prime even if I covered the stinger.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
JL Racing .12 nitrodude Onroad Nitro Engine Zone 2083 05-16-2012 01:21 PM
MEGA (by Picco) thread ttso Onroad Nitro Engine Zone 1318 09-13-2010 04:56 PM
Turf City 1/8 Off Road Buggy Race, 20th Apr 2008. leng Singapore R/C Racers 66 04-23-2008 09:22 AM
2007 RCMC Singapore National Championship (8th & 10th Scale On Road GP) sunny Singapore R/C Racers 49 02-21-2007 08:48 AM
ITS SAD IM A NOOB AND NO ONE WILL HELP HOW IS THIS GREAT SPORT SPOSE TO GROW rhymster Electric Off-Road 20 05-17-2006 03:01 AM
