Old 05-26-2009, 06:05 AM   #1
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Default Chassis brace on RC8, how to take it off?
I kept popping out a hinge pin on one of my front a-arms on my RC8, because the screw that holds it in isnt doing the job. So I need to pull it out, add a washer and it will be fixed. I took the 4 screws out of the bottom of the front end, and the 2 on top the steering rack, but the steering rack is in the way of unscrewing the chassis brace, which is the last piece holding the front end on. Is there some trick to getting to that last screw?
Thank you to the following companies for their support in 2017:
* Futaba * O.S. Engines * RC Racing Communications *
CaptainHowdyt13 is offline   Reply With Quote
Old 05-26-2009, 06:27 AM   #2
mfrosty's Avatar
Trader Rating: 14 (89%+)
Unscrew the other end of the brace near the center diff. There's no way to remove the screw on the brace in the front with the top plate still on.
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 05-26-2009, 06:34 AM   #3
Ok, this makes sense. Thanks man.
Old 05-26-2009, 06:41 AM   #4
scwrod's Avatar
You can remove the whole front clip in one piece.
7 screws and the steering servo.
The trick to the chassis brace is:
You have to push down on the top of the chassis brace where it connects to the chassis while removing the screw from the bottom. If you notice there is a recessed cut out. This will grab the bottom of the ball cup(??) if you press down.
Hope this helps.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 05-26-2009, 06:47 AM   #5
Hope this helps.
I dont get this...lol
Old 05-26-2009, 07:07 AM   #6
n10cities's Avatar
The ball stud that the brace fastens to on the chassis has flat edges on two sides that key into the recessed slot on the chassis so it won't rotate. When removing the screw from the bottom of the chassis, make sure you press down on that ball stud while backing the screw off so it won't start spinning around and keep you from backing the screw out...
Your arrogance blinds you.....
Losi - Spektrum - Byron's Fuel - Airtronics
Robbie
GSHobby.com
n10cities is offline   Reply With Quote
Old 05-26-2009, 07:07 AM   #7
Shane Racer's Avatar
To remove the chassis brace from the top plate you will need to take the front upper arm off to get to the bolt.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 05-26-2009, 11:47 AM   #8
scwrod's Avatar
Old 05-26-2009, 12:43 PM   #9
I guess I shouldn't assume everyone is using an aluminum top plate.
Old 05-26-2009, 01:04 PM   #10
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
I guess so!
But it is the number one mod you should do!
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 05-26-2009, 04:15 PM   #11
Originally Posted by JoeyTheRocket View Post
I guess so!
had a blonde moment I guess. The bolt i am talking about is to take the top plate off not the chassis brace. All though once you take the top plate off you can get to the chassis brace.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
