Old 05-25-2009, 11:29 PM   #1
ntc3bionicracer's Avatar
Send a message via ICQ to ntc3bionicracer Send a message via AIM to ntc3bionicracer Send a message via MSN to ntc3bionicracer Send a message via Yahoo to ntc3bionicracer Send a message via Skype™ to ntc3bionicracer
Default jato's brakes
i just broke in a new jato and when finished and started to run fast and wide open after the 5th tank of fuel,,the brakes do not work well at fast speeds they work well at lower speeds they are working correct it seems anyone have any info, is there a better system to replace the stock stuff ???? any info where to purchase
ntc3bionicracer is offline   Reply With Quote
Old 05-26-2009, 09:47 AM   #2
markr04's Avatar
I don't think there's much you can do about that. It's a 2WD car (brakes are at the rear wheels only) and it goes 60+ MPH. The Traxxas forum has some posts about using antenna tube to increase the servo's action on the pull, which allows it to lock the brakes.
If you leave the brake system alone, you'll have slower stops that are controllable. If you use the antenna tube mod, you can lock the wheels when braking but won't have control because of it. I tried the antenna tube mod, but ended up removing it.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 05-26-2009, 12:31 PM   #3
madmaxx's Avatar
follow the link in my sig and have a look at the rear brake kit
made a WORLD of difference on my REVO! which uses the same rear brake's as your JATO
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 05-26-2009, 12:51 PM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
BUT you have to have a center diff on the revo to use the rear brake kit
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 01:12 AM
Put some Trac-Ta-Gator tires on my JATO3.3 BashemSmashem Electric Off-Road 8 03-21-2007 11:06 AM
