16mm Big Bore Shocks RC8
Howzit Guys,just want some feed back of some of u that may have
the 16 mm big bore shocks on your RC8,i dont know if i should get them,
want to know if they really make a big def on the car's handling.
And what oils and spring i have to use.Thanks
Ok,cool.So i will get them,and the new RC8B looks good but i dont like the alu STower but everything else looks good,thanks for your info.
cary
The setting u talking about is that for a smooth or bumpy track,
How did u know that i dont like to toy alot with settings ?
But thanks i will get the 16mm shocks and try your setting.
I picked up a set a few weeks ago and put them the rear on b/c the front came with a defective shock shaft. Before I put them on the car spent alot of time on its lid, but now I can pick up the throttle way sooner, not to mention landing huge jumps. Im running like 25 in the rear with the stock pistons, I think I will try the 30 next weekend
I think that Big Bores is the second best investment you can make in improving your handling, tires being the first (AKAs all the way). You will be so much more stable in the turns increasing cornering speed and faster in the straights on bumpy tracks especially in the rear end
My thunder tiger eb4 wont start please help
Hi basically i have got a thunder tiger eb4 but i cant get it started some one fiddled around with the 3 needle adjustment valves and i dont know what they should be set at. Can anyone please help me. Thanks
