Old 05-25-2009, 11:35 AM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default which tire glue
Ive been using losi "standard" but it hasn't worked very well - I dont know maybe the glue went bad. I always sand the wheel and tire and wash everything with acetone and denatured alcohol.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 05-25-2009, 11:40 AM   #2
mfrosty's Avatar
Trader Rating: 14 (89%+)
1 word. Premounts
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 05-25-2009, 11:42 AM   #3
Integra's Avatar
glue can 100% go bad....you really should keep it in the fridge in a zip loc of some sort......for Glue i have been using AKA with awesome results....it seems to be imo the best glue on the market and ive tried my fair share of them out there.
and yes the bottle is only meant to come 1/2 full as you will never use a full bottle in time before it goes bad unless you store it in the fridge.
Old 05-25-2009, 11:52 AM   #4
wstuart's Avatar
yeah im thinking premounts form now on. Ill try the glue in the fridge. Thats probabyl been my problem - ive had my glue for a while
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 05-25-2009, 12:01 PM   #5
mfrosty's Avatar
AKA premounts are where it's at! I just started running the premounts and I've got 3 full sets. Not one tire is out of balance! Their foams are stiff so you have to set your car up a little softer to compensate, but they also don't shift on the rim and they feel the same everytime out. They're VERY consistant.
Old 05-25-2009, 12:14 PM   #6
cary's Avatar
Trader Rating: 67 (100%+)
+1or2 on the AKA premounts just made the switch over form pro-line
the balance is spot on i seam to like them a lot more and
no more gluing them up
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 05-25-2009, 12:55 PM   #7
wstuart's Avatar
how are the losi pre mounts?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 05-25-2009, 01:27 PM   #8
losi_racer's Avatar
Trader Rating: 25 (100%+)
on ANY premount you get run a thin bead of glue on the outside between rim and tire and let it dry before you even think about runnin them and they will never come off
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-25-2009, 01:47 PM   #9
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
AKA premounts already have that bead.......I just got 4 sets and they are DIALED
As for tire glue seperately, AKA or Lucky7
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 05-25-2009, 02:45 PM   #10
Integra's Avatar
doing this leads to to a chunky bead when it comes time to reglue the small area's that do lift...as its alot harder to clean a cracked up chunky bead then it is a smooth tire/rim bead.....i used to use the thin bead trick but found it more hassle then it did good....all i do now is fill the gap and wipe the excess away with a cloth.
Old 05-25-2009, 07:23 PM   #11
j_blaze14's Avatar
Trader Rating: 34 (100%+)
losi glue has not worked for me at all, i thought i was a horrible gluer until i tried the great planes thin and fusion thin, my tires do not come off. i ruined about 4 sets of tirs using losi glue, then between heats having to reglue, clean and reglue, it got old quick. from my experience losi glue is junk.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 05-25-2009, 07:39 PM   #12
Troy Pinkston's Avatar
I have been using the Racers Edge FUSION glue for quite some time now. I have just recently switched over to the O'Donnell brand glue. It is very thin and seems to be working just as well if not better than the FUSION. As with any glue, tire prep is key. I also refrigerate all glue when not in use.
ODOR3000 is the part number.
Troy Pinkston is offline   Reply With Quote
Old 05-25-2009, 07:44 PM   #13
BIG RE's Avatar
Trader Rating: 32 (100%+)
I'm going crazy as of late trying to keep tires on the rims, I have tries all sorts of different prep methods over the years, but in the last few months I have been having lots of problems no matter what prep I do, I was using losi thin and regular, then switched to aka glue, and it's the same result, I'm thinking of using fusion through the aka/losi bottle, I used fusion once before and found it to be to thin to handle, what is working for you guys?
BIG RE is offline   Reply With Quote
Old 05-25-2009, 07:50 PM   #14
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
The key to glue is freshness. My glue is produced in the USA on a daily basis and stored cold till shipping to assure the freshest High Quality Tire Glue available.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 05-25-2009, 07:57 PM   #15
Trader Rating: 30 (100%+)
imo aka premounts are good but thier glue has been having issues seen alot of them coming loose i use losi red glue have had good luck with it i wipe tire and rims with acetone then glue them up using alot of glue to point where have to whipe off all the excess. also never use the glue bottle more then once so i wait until i have several sets of tires to glue then do them all at once with fresh bottle of glue what ever i dont use gets thrown in the super glue drawer for my wife. i havnt had a tire unglue in a long time. oh yeah i have buddy making a tire gluing rig for buggy tires that is off the hook as soon as mine gets to me will post the pics and prices on snatching one up 4 your self
jewn_beef is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
Installing foam donuts? Rc guy Electric On-Road 18 01-23-2013 10:35 PM
Tire glue? lowey79 Nitro Off-Road 17 09-11-2008 04:23 AM
Mounting 1/8th scale tires Dougg Nitro Off-Road 13 10-10-2007 07:56 PM
New K Factory tires wiggindude6969 Nitro On-Road 62 04-13-2007 10:11 AM
Reedy Race Of Champions Painy Australian Racing 140 12-17-2003 01:00 PM
The N/w Trcr`s pits Talk V-3 Wild Cherry Northwest Racers 3531 10-17-2003 08:33 AM
