Old 05-25-2009, 08:25 PM   #16
Frank L's Avatar
Trader Rating: 148 (100%+)
AKA premonts are ok but if you like to mount your own AKA glue is the best.
Old 05-25-2009, 08:40 PM   #17
Suspended
Originally Posted by BIG RE View Post
I'm going crazy as of late trying to keep tires on the rims, I have tries all sorts of different prep methods over the years, but in the last few months I have been having lots of problems no matter what prep I do, I was using losi thin and regular, then switched to aka glue, and it's the same result, I'm thinking of using fusion through the aka/losi bottle, I used fusion once before and found it to be to thin to handle, what is working for you guys?
Wahahaha !!!, pardon all the laughters cos I've been in that position too & can understand your hair-pulling frustration We've tried any brand of glue you can name, OK-Bond, Zap-it, Much More, blah, blah.... & would only swear by 'Loctite 406', the CA(superglue) specially made for hard-to-glue plastic & rubber.
Remembered years ago, the first pre-mounted tires was proudly presented by Medial-pro...... but then quickly despised due to them coming loose easily. Then we have Pro-line following suit & with same problem as well, other than with the addition of their molded insert disintegrating inside. OMG, how we hobbyist lazy to glue tires were pulling ourself bald back then.
TonyNg is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
Installing foam donuts? Rc guy Electric On-Road 18 01-23-2013 10:35 PM
Tire glue? lowey79 Nitro Off-Road 17 09-11-2008 04:23 AM
Mounting 1/8th scale tires Dougg Nitro Off-Road 13 10-10-2007 07:56 PM
New K Factory tires wiggindude6969 Nitro On-Road 62 04-13-2007 10:11 AM
Reedy Race Of Champions Painy Australian Racing 140 12-17-2003 01:00 PM
The N/w Trcr`s pits Talk V-3 Wild Cherry Northwest Racers 3531 10-17-2003 08:33 AM
