Old 05-24-2009, 04:25 PM   #1
pl_unc86's Avatar
Trader Rating: 16 (100%+)
Default Nova 21-5 question
So i am having some tuning issues... heres exactly what is happening!
So after starting the engine and getting it to temperature after getting on the throttle and then letting off and getting back on, it will start to sputter and its almost impossible to get it to come back and then within 10 seconds the car cuts off.
During the main my car tended to cut off right after our big straight!
I was temping anywhere from 240-250 which i didnt think was hot enough to cause the motor to just quit.
Compression is fine
Any help would be great, this issue prevented from finishing two quals and after to restart the buggy at least 6-7 times during the main.
pl_unc86 is offline   Reply With Quote
Old 05-24-2009, 04:37 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Compression is fine
short fuel line from tank to carb and way too rich on the low speed ?
maybe the shimming in the head got messed up , too few shims ?
hard to diagnose when the engine isn't here
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-24-2009, 04:44 PM   #3
pl_unc86's Avatar
I know its hard to come up with the right answer just trying to get as many opinions as possible. A buddy of mine mentioned the rear bearing???
I didnt have the problem if i remember correctly when i first started out the day and then made some tuning changes. So i would think its just in my tune but not sure if its the high end or low end...
Since it was cutting off almost in the same spot everytime during the main ( after the big straight) wouldnt that be something in the top end?
Old 05-24-2009, 04:54 PM   #4
Default re
try a hotter plug lean the low an hour at a time keep trying it should help also how long is your pressure line might be too long
toofless is offline   Reply With Quote
Old 05-24-2009, 05:19 PM   #5
houston's Avatar
idles too low and low too rich if it is dieing at the end of the straight away
find a tuning guy in your area
Old 05-24-2009, 06:21 PM   #6
pl_unc86's Avatar
was just messing with it on the deck while turning back some beers...reset it to factory and its still sorta rich but its not doing the sputtering crap anymore...so thats one thing fixed hopefully
Prob was the beer!
JP engines jasoncsc Onroad Nitro Engine Zone 1160 05-10-2017 07:19 AM
Sirio S21 CL7B .21 Long Stroke marki Offroad Nitro Engine Forum 398 10-12-2011 01:23 AM
QUESTION FOR THE NITRO ENGINE EXPERTS !! dead1dave Nitro Off-Road 14 07-11-2009 04:14 PM
General Nitro Engine Question CaptCrunch Nitro Off-Road 9 12-16-2008 05:47 AM
Engine choice question CanyonCarverR1 Nitro Off-Road 12 09-12-2008 02:35 PM
newbie to buggy 1/8 .21 motor question teabag Electric Off-Road 19 05-30-2006 01:54 PM
Engine Wars Thread EVOLUTION Nitro On-Road 697 12-15-2003 10:18 AM
