Old 05-24-2009, 12:44 PM   #1
Default Starter Box Lipo Problems
Hi all
I have just fitted my starter box with a 14.8v 4000mah lipo battery with a 15c burst discharge rate. It spins up AWSOMELY fast but just doesent seem to have the torque to turn the engine over. Any ideas i bought the lipo from ebay and it is labeled as above but it just doesent seem to have the umph to turn the engine over.
gddevey1012 is offline   Reply With Quote
Old 05-24-2009, 12:57 PM   #2
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
15C burst? If so, it's definitely not enough. Starter box motors can draw pretty high amperage. 15C continuous with a 60C burst would be fine, but 15C burst won't work.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 05-24-2009, 01:19 PM   #3
* Capacity: 4000mAh
* Voltage: 14.8V
* Cells : 4
* Burst Rate : 15C
* Continuous discharge rate: 10C
* Size :145mm x 48mm x 25mm
* Weight: 346g
thats the spec of it
Old 05-24-2009, 01:23 PM   #4
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
Batteries probably can't put out the amperage to keep it going after the burst...
If you have another pack that's exactly the same, wire them in parallel, then you'll be set.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 05-24-2009, 01:39 PM   #5
Integra's Avatar
you got suckered into the 1 thing i warn about buying lipo's from Ebay.....NEVER BUY anything that is less then 20C.....basically fork over another 30-40$ and find a 20C or better pack.....25 or 30 will also be fine.
Old 05-24-2009, 02:03 PM   #6
malcnz's Avatar
sorry to hijack the thread...
I am getting a Losi box and a guy I know is selling a 5000mah 4s 1p.14.8v,.. 12c constant and 15c burst..would this be O.K?
Thanks.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 05-24-2009, 02:10 PM   #7
Integra's Avatar
Thanks.
Imo no...20C is Minimum when it come's to anything drawing significant amperage.
Old 05-24-2009, 02:14 PM   #8
malcnz's Avatar
Cheers,
have a couple of brandnew 12volt gel cell 7.2 AH leadacids and would these be better?
Thanks.
Old 05-24-2009, 02:23 PM   #9
drperry's Avatar
Just use one of them at a time
Old 05-24-2009, 02:25 PM   #10
malcnz's Avatar
Ha..yeah true.
Thanks.
Old 05-24-2009, 02:27 PM   #11
drperry's Avatar
Well, you COULD wire them both up in parallel, but that'd be a pretty heavy starter box
Old 05-24-2009, 03:42 PM   #12
malcnz's Avatar
I might do that as also will use it to charge my receiver batteries/glow starter if they need it during racing so will most likely use the external cord from starter box to attach to battery.Thanks.
Old 05-25-2009, 01:40 AM   #13
so as i have 2 of these cell packs would wireing them in paralell work or should i not bother ?
Old 05-25-2009, 01:56 AM   #14
drperry's Avatar
Wiring them in parallel should definitely help.
Old 05-25-2009, 02:31 AM   #15
bmxRRT's Avatar
http://www.amainhobbies.com/product_...ducts_id/32997
O'Donnell Z01-B(E) Team
Mamba Monster 2200kv
Futaba BLS 451
Airtronics M11x
bmxRRT is offline   Reply With Quote
