Old 05-24-2009, 07:16 AM   #1
Default Can anyone offer some help for a motor that sat for a year not ran? Issues starting..
I have a Jato which runs great, my neighbor's son has a Tmaxx and seen me running my car so decided to get his out. It's in great condition but he hasn't ran it in over a year and never cleaned the motor out before he shut it down.
When we place the battery pack on the truck to start it, it starts to turn then it locks. We removed the glow plug drained all the gas and then cycled the motor with the plug out and it spun freely as usual.
I then placed a new glow plug in and it turned over for about 2 minutes but shot gas out the pipe like crazy. Still wouldn't fire.
I let it sit for a few minutes and now it's doing the same thing again as soon as you try to start it, the motor only turns a revolution and locks. When you remove the glow plug it turns over. Obviously the gas comes out the glow plug hole but it turns over...
Can anyone suggest any ideas?
spankey73 is offline   Reply With Quote
Old 05-24-2009, 07:23 AM   #2
heat the engine to about 200 degrees then try again. It also sounds like it is too rich
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-24-2009, 07:26 AM   #3
He did fool with the high end screw which I set back to factory settings. I guess we will have to let the engine sit out today in the sun and then give it another whirl......
Old 05-24-2009, 01:41 PM   #4
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
It was probably overly rich, if it's flooding like that...
Also, did you get a new glow plug for it?
My 2.5 sat for two years (being completely filled/soaked in WD40, but still) and fired right up, once the EZ-Start one-way could catch the crank shaft
Starting at factory settings is a good idea!
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 05-24-2009, 01:53 PM   #5
Yep, it sure was. I removed the glow plug and the piston was full of fuel. I drained the fuel from the tank and ran all the fuel out with the glow plug removed.
Re installed the plug and sure enough it fired right up!!!!
Running great now.
Old 05-24-2009, 02:22 PM   #6
drperry's Avatar
Good to hear you got it up and running!
