Old 10-14-2009, 09:32 AM   #76
Frank L's Avatar
Trader Rating: 148 (100%+)
Man this is getting complicated 1 dot 2 dots etched v2 over the exaust port 1 shim 2 shims never 2 shims damm at least I follow instructions well. I love your stuff Ed but hats alot to keep track of. What if the dots or v2 aren't over the exaust port is that bad? Cary I'll have to let you do the stuff for me you seem to be on.
Old 10-14-2009, 09:34 AM   #77
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Originally Posted by Frank L View Post
Man this is getting complicated 1 dot 2 dots etched v2 over the exaust port 1 shim 2 shims never 2 shims damm at least I follow instructions well. What if the dots or v2 aren't over the exaust port is that bad? Cary I'll have to let you do the stuff for me you seem to be on.
if you didn't start with the dots over the exhaust just make sure it goes back the same every time... the purpose is to keep the burn pattern the same..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 10-14-2009, 09:45 AM   #78
cary's Avatar
Trader Rating: 67 (100%+)
don't know about that just got lucky on this one
you know me I only read the instructions when all else fails
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 10-14-2009, 10:02 AM   #79
Frank L's Avatar
Lol
Old 10-14-2009, 06:53 PM   #80
TonysScrews's Avatar
Originally Posted by oggietiu
Hi tony, got this from the mugen site. It accurately answered my shimming question. I really made a mistake in shimming cause i used the copper shim 25% nitro and p4. But more than this I thing metal fatigue was the main issue why the piston shattered. Can wait to put this on the speed.
UPDATE!
New V2 (version 2) EB Mod JX-21 Head Buttons
The new V2 head buttons offer the same performance gains as the V1 head buttons but allow for further tuning options. The shimming has changed on the V2 head buttons.
The standard shimming is now one 0.2mm (0.008") aluminum shim for 30% nitro and altitudes under 3500 feet. If you're in higher altitudes (above 3500 feet) and run 30% nitro the deck height is dropped by using the 0.1mm (0.004") copper shim instead. With the V1 head buttons you had to run 40% nitro since you could not drop the deck height.
For extended run times using 20% nitro fuel use the 0.1mm (0.004") copper shim only. Testing has seen an increase of almost two minutes run time. Of course the motor makes less power on 20% fuel but with the performance gains of the head button it can be a nice trade off (especially since 20% fuel is cheaper than 30%).
Ed also recommends the use of a P4 plug due to inconsistencies amongst 30% nitro blended fuels (just because the label reads 30% does not mean it's 30%). Personally I haven't had any issues running the P3 plugs in my JX-21 B01 engine but a very small number of guys have had tuning issues. If you have P3 plugs I would use them unless you see signs of detonation on the plug or have tuning issues. On the dyno, the motor makes better power using the P4 plugs. If you're running 25% nitro fuel, follow the shimming instructions for 30% and use the P3 plugs.
The V2 plugs can be easily identified by two marks machined into the top of the head button.
_ _ _ _ _ _ _ _ _ _ _ _ ____
Tony P.
Originally Posted by blade954 View Post
I shimed my engine from this above thread, But im not sure on the the two V2 dots over the rear exhaust port will check this out when i get home. I'm happy with the out come of the head button on the Speed 2(Hara edition) and was looking at getting another for the standard V Spec as well.
I will head over to the Mugenracing forums and update that thread with the new info from Ed. Basically, follow whatever instructions came with your EB Mod head button. There were only a few updated V2 head buttons that went out with the instructions above. All of the V2 head buttons that went out recently have the new instructions Frank posted below.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 10-14-2009, 10:32 PM   #81
blade954's Avatar
Trader Rating: 23 (100%+)
So by placing the two "dots" over the rear exhaust it will help in economy and power or is the button designed to run like that and say if its at the front your not getting the most out of the button, I was stoked by the gains we got 10min with out fail now.....And power to boot....Actually mated to a Os 2050 and a 15t bell on the 808 it was a missile....
blade954 is offline   Reply With Quote
Old 10-15-2009, 08:05 PM   #82
It doesn't matter which way the dots are facing when you install the head button. The performance will be the same. But if you run the motor and then take the head button off and go to re-install it you should "try" to face the dots in the same direction. But if you don't the head button will still perform fine. It's more of an OCD thing....LOL
Tony P.
Tonys Screws LLC
Old 05-18-2010, 10:01 PM   #83
Can i still buy these head buttons?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-18-2010, 10:38 PM   #84
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Yes tony screws web site
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 05-19-2010, 12:49 AM   #85
Greenlee37's Avatar
Trader Rating: 32 (100%+)
sold out everywhere I look... anyone know where they are in stock?
Greenlee37 is offline   Reply With Quote
Old 05-19-2010, 08:14 AM   #86
I should have them back in stock by Friday. I also have some fully modified EB Mod JX21-B01A's coming in.
Best regards,
Tony P.
Tonys Screws LLC
Old 07-22-2010, 11:15 AM   #87
Robert Walker's Avatar
Trader Rating: 74 (100%+)
Send a message via Yahoo to Robert Walker
I have one still in the package that I would be willing to sell. PM me if interested.
EB Mod JX-21 Head Button V2
Robert Walker is offline   Reply With Quote
Old 07-22-2010, 11:35 AM   #88
Frank L's Avatar
These things rock
Old 07-22-2010, 03:25 PM   #89
Head buttons are back in stock....but going fast...lol
Tony P.
Tonys Screws LLC
Mugen JX21 jlinds Offroad Nitro Engine Forum 1448 03-19-2015 07:22 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
V-Spec fuel consumption tweaking Amoeba Nitro Off-Road 9 08-04-2009 02:46 PM
os speed quicklosi Nitro Off-Road 6 07-20-2009 01:46 PM
DONT BUY A V-SPEC!!!! GMS_Racing Nitro Off-Road 193 06-13-2009 06:03 AM
