Old 05-23-2009, 06:48 AM   #1
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Differential.
Hi, may I know why my differential oil going black when I open up? Can a differential oil going less or mean left 30% inside the differential case after 2 months run ( ~8 times ) if no leaking? Thanks.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 05-23-2009, 07:01 AM   #2
madmaxx's Avatar
if you don't fill the diif to the top you leave air in the diff and it aerate's the oil breaking it down faster....
my $0.02
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 05-23-2009, 07:20 AM   #3
tkhoo's Avatar
my $0.02
Hi, I always filled 80-90% full and close. Is that consider ok? May I know what you mean "it aerate's the oil breaking it down faster"? Thanks.
Old 05-23-2009, 07:33 AM   #4
Trader Rating: 30 (100%+)
you hsould fill diffs to just pass the cross bars meaning just above where the two shafts cross and as for the oil you should change it after a few track days it want it to feel the same all the time diff. fluid breaks down and turns the dark color yhour speaking of
jewn_beef is offline   Reply With Quote
Old 05-24-2009, 10:28 PM   #5
tkhoo's Avatar
oic....just filled over the cross bar...I used to filled almost full of the differential case Ok, I will follow your advise on next service. You mean the diff oil turn to dark colour is normal and it turn to dork due to over used? Please advise. Thanks.
Old 05-24-2009, 11:48 PM   #6
The gears inside the diff are aluminum & rubbing together even in oil will cause slight wear at worst & a continual polishing at best & the tiny alum particles is what turns the oil dark gray.Its normal & a little leaking out past the o-rings during use is normal also for most diffs.
butch man is offline   Reply With Quote
Old 05-25-2009, 01:04 AM   #7
tkhoo's Avatar
OIC.......because of the aluminium rubbing and cause the diff oil going dark.........So in my case it was normal and only thing is I need a little hardworking to change the diff oil regular, right? :
Old 05-25-2009, 06:54 AM   #8
Integra's Avatar
basically yes...and you DO NOT fill the cup right up to to the top...you only go as high as the cross pins as Filling the diff right up will cause inconsistency in the diff itself....air in the diff oil is Nothing you will get away from...they are Not 100% sealed units.
Traxxas Revo futureal Monster Trucks 3272 04-30-2017 03:46 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
New Track The Coliseum @ Hobbytown Frederick Slotmachine Racing Forum 5946 10-06-2006 02:10 PM
Super Hopped up Savage 25 for Sale. I'm jumping to 1/8 scale KansasCajun R/C Items: For Sale/Trade 11 08-31-2004 01:27 PM
