Old 05-22-2009, 09:15 PM   #1
Default Rear diff.
I just got a second hand Tamiya nitrage truggy the other day. I took it out for a run. It went fine for two tanks then it developed a clicking sound in the rear diff. I pulled the diff apart and found that the small gear that drives the big gear was rounded and almost stripped. Im not sure how that could happen cause they are both steel gears Why would it do this, is it because of ware or because they weren't meshed properly? Also isnt the diff meant to be full of oil? I have never taken one apart before so I dont know but I see diff oils advertised in model shops. The diff I pulled apart barely had any oil at all. Could this be the problem.
Silencedsteak is offline   Reply With Quote
Old 05-22-2009, 09:33 PM   #2
Could be shimmed wrong, and the lack of oil probably had something to do with it.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-22-2009, 10:55 PM   #3
What does shimmed mean?? Bear with me I have never pulled the diff apart berfore.
Old 05-22-2009, 11:11 PM   #4
Basically it means the mesh of the gears,and you add shims (washers) to adjust it.
I've never done it, haven't needed to yet.
LRP Z.28R - 3
Spur Gear - 0
Old 05-22-2009, 11:19 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
you usually dont have to, you shim them if the gears are worn like yours but i would suggest gettin new gears and while your at it check all the diffs and shocks and put new fluids in all of it
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-22-2009, 11:38 PM   #6
I did a search for diff oils and there is alot of different types. Which one should I get and how much do I need?
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 03:31 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
your WTF moments in RC phixd Nitro Off-Road 380 02-27-2009 07:10 PM
AH12 For Sale! 429racer R/C Items: For Sale/Trade 9 12-10-2005 09:45 AM
