Charging Gel Cells
Charging Gel Cells
For those of you that use the wall charger for your gel cells.
How long do you keep it on the charger. I am a little hesitant to leave it over night due to a fire or something.
In general how do you know if it is fully charged. The reason why I ask is I don't let the battery die so how long am I suposed to charge.
So you can plug it into the wall(AC). Otherwise you have to use a car battery(DC).
I have the mrc super brain 989. It charges gel cells. I was gonna use it instead of the wall charger but Im unsure as to how many cells these batteries have. it goes from 1-5 on my charger. The directions are unclear with my charger so I have never used it to charge my gel cell. Should I charge at 1 amp also ? I know these batterys are 7ah so that would be 7000 mia, correct ? someone please clarify the number of cells for me please.
http://www.amainhobbies.com/product_...ducts_id/36965
you can charge it at 2 amps in about 6 hours or 1 amp in about 10 hours
I believe a gel cell, is just 1 big cell..as long as you dont go over 2 amps I believe you will be fine
well I am curious now, since I have had two starter box batteries go bad this season (both almost 2 years old). I have always used these: http://www.redrockethobbies.com/Hang...tm&Click=29184 with the Hobbico wall charger. i was told to just plug em and forget em.... But twice this year I had them go bad on me... ?????
