Old 05-22-2009, 11:58 AM   #1
Maximo's Avatar
Default Spider Gear upgrade for Jammin ?
Does anyone know what I can do to upgrade the Spiders on my Jammin diffs ? Well its not a jammin but rather my DM-1, which uses the same diffs.... My current stock spiders are already showing excessive wear at 1 gallon, I need to order new spiders but I would rather order something stronger then stock if possible.... anyone have any ideas ?
Maximo is offline   Reply With Quote
Old 05-22-2009, 12:36 PM   #2
dethklok151's Avatar
Trader Rating: 64 (100%+)
kyosho ones will fit,at least from the 777 series.hot bodies ones should fit as well,i think they are hardened steel,but were often changed out because they were "notchy"(from the lightning series).the kyoshos are aluminum as well,but are enexpensive.stronger or better,idk,but it is a place to start looking.you could shim yours as well
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?"
dethklok151 is offline   Reply With Quote
Old 05-22-2009, 03:10 PM   #3
jazjato's Avatar
Try the ones from the hyper st pro truggy. I never had a problem with mine. Being an Ofna product the should fit right in.
jazjato is offline   Reply With Quote
:::::Hyper ST Electric Conversion::::: Hyper ST-E Guy Electric Off-Road 12 11-11-2010 03:41 PM
