Old 05-26-2009, 06:06 PM   #46
freestylinmotox's Avatar
When do you guys usually seal your motors? after break in? for inspection? every couple gallons? every race?
-Thanks
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 05-26-2009, 06:13 PM   #47
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
-Thanks
Before breakin. Or
If you use a breakin bench of any sort. Break in the engine, then with the pinch bolt loose mock up the fit in your car with the linkage, then tighten up pinch bolts and seal.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 05-26-2009, 06:58 PM   #48
So, is it ok to seal a motor that has been run through about a gallon?
cassidy is offline   Reply With Quote
Old 05-26-2009, 07:01 PM   #49
jpalessi's Avatar
absolutely! just clean it up good and seal
Joe Alessi
www.Lucky7RC.com
Old 05-26-2009, 07:03 PM   #50
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
You can seal a motor whenever you desire, just make sure you clean the area with motor spray and a rag. I used to seal my motors, but I haven't done it for a while. I used to do it every time I took apart and cleaned my motor. Hope this helps!
CJ Weaver is offline   Reply With Quote
Old 05-26-2009, 07:40 PM   #51
Do you seal the carb and pinch bolts while the carb is on?? Or do you take it off apply a think bead at the bottom then push it back into the intake??? same thing with the back plate??? Just apply it around the backplate while it's installed???
dreaux is offline   Reply With Quote
Old 05-26-2009, 07:50 PM   #52
jpalessi's Avatar
Seal while parts are installed. do NOT apply internally
Joe Alessi
www.Lucky7RC.com
Old 05-26-2009, 07:53 PM   #53
CJ Weaver's Avatar
If you take the backplate off and seal the bead, it will work pretty well. You want the sealant to be between the backplate and case. Same thing with the Carb.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
Old 05-26-2009, 07:56 PM   #54
ok thanx. air leaks have driven me crazy before. Took me 3 days to find it one time.
Old 05-26-2009, 07:59 PM   #55
jpalessi's Avatar
no you don't... not with Lucky7 anyway. This is how many ppl suck sealant into their engine. best way to seal a nitro engine with any product you decide to use is a thin bead externally. When sealing use like a coating, not a gasket.
Joe Alessi
www.Lucky7RC.com
Old 05-26-2009, 08:17 PM   #56
CJ Weaver's Avatar
Hmm...I will keep that in mind I guess. I have never had an problems using this technique. If you apply it to the outside, how exactly does it "seal" the engine. If the sealant doesn't get in between the cracks, is the sealant really doing anything? I'm not an expert at sealing motors so any responses will be much appreciated!
Old 05-26-2009, 08:35 PM   #57
jpalessi's Avatar
That method may work with other sealants that are designed to work like a gasket but as far as my knowledge there is NOT many Nitromethanol safe sealants out there. "Fuel Safe" does not mean NITRO safe so i would test anything you plan to use before you use it. In my time testing and producing engine sealant i have seen WAY to many engines suck many different types of sealant through. some do harm, some don't, but either way this is something to avoid. This is why i decided to make a very thin wicking sealant that would work around easily and fill cracks and crevices. If you notice when using Lucky 7 after it drys it shrinks drastically and may require another coat. This is good! lol
Joe Alessi
www.Lucky7RC.com
Old 05-26-2009, 08:44 PM   #58
CJ Weaver's Avatar
OK, thanks! I will make sure I use that method if I ever change sealants!
Old 05-26-2009, 08:55 PM   #59
jpalessi's Avatar
No problem..
Joe Alessi
www.Lucky7RC.com
Old 06-20-2009, 06:01 PM   #60
sickmojave's Avatar
OK. I got my bottle of Lucky7 in hand and have read this thread and a few others. I have yet to find anywhere that says what you use to apply it with. Q tip? paint brush? dump it on and hope it soaks in the right places(LOL)?
sickmojave is offline   Reply With Quote
Go Tech Engines pino Onroad Nitro Engine Zone 331 08-04-2009 08:39 PM
picco 28, junk??? dayglo33 Electric Off-Road 22 06-24-2009 09:56 PM
Internal engine troubles new to rc cars Nitro Off-Road 9 05-14-2008 02:08 PM
Anyone fimilar with the Hyper 21 8 Port Git R Done! Electric Off-Road 9 06-18-2006 01:01 AM
Sealing a new motor jcrouse Nitro On-Road 13 08-22-2003 01:17 AM
