Old 05-21-2009, 07:16 PM   #1
triggerman101's Avatar
Trader Rating: 102 (100%+)
Default buggy only runs when....
so im out playing with both my buggies and they are running fine. was playing with the first one which i had to change the plug in before i ran it. it died on me the last time i drove it which was monday. changed it with the same plug i have been using. its running fine, then it dies.ok maybe out of gas. not out of gas but close. fill it up and started it with no problems but it took just a couple seconds longer. get it back on the ground and it dies. i just filled the tank. so i start it back up and rev it up a couple times. ok so its running fine. take the ignitor out and put it on the ground. made it about 50ft and it dies. i start it back up and it is running good but it will only run good with the ignitor on the plug. both buggies are doing the same thing. the motor im talking about above is a rb ws7III. the other is a hyper 21 bump start.
so basically the only way they will run off the box is with the ignitor on the plug.
same gas as i was using on monday and it has been in the house, using the same plugs i have been using, radio(m11)has low batteries and it beeped at me, and they both have fail safes. the lights on the fail safes are not doing anything different from when the batteries are good. those three things are the only ones i have thought about the problem being. any help would be appreciated.
Mbx7r, mbx6t(still)
dialedhobbies.com
AKA, James, 4px, Hitec
triggerman101 is offline   Reply With Quote
Old 05-21-2009, 07:43 PM   #2
tc5 man's Avatar
i would check your clutch and the clutch bearings and the clutch bell see if that works
tc5 man is online now   Reply With Quote
Old 05-21-2009, 07:59 PM   #3
i checked that on the ws7. i figuered since they are both doing the same thing, that maybe the plugs im using dont like warmer weather or the fuel im using or something. thanks for the reply.
Mbx7r, mbx6t(still)
dialedhobbies.com
Old 05-21-2009, 08:04 PM   #4
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Was it extremely humid today compared to Monday? I have trouble with the bottom end going rich on me when it gets really humid, causing flameouts
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 05-21-2009, 08:15 PM   #5
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
I will check on my idle gap. Remove the filter and see the gap. It will be around 1-1.5mm. Then start from there retune your engine. If still die, change another plug and see how it work.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 05-21-2009, 10:14 PM   #6
i thank you guys for the replies. im going to try to check the lowend needle first. if that doesnt do it then ill get some hotter plugs and try them.
Mbx7r, mbx6t(still)
dialedhobbies.com
Old 05-22-2009, 12:09 AM   #7
Rampokker's Avatar
Also make sure the glow igniter battery is fully charged. When you've got the plug out, check that it glows like it should when you put it in the igniter. I had a problem where my igniter wasn't making good contact with the plug. After cleaning the igniter contact area, it worked perfectly again.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 05-22-2009, 12:34 AM   #8
az00lude's Avatar
Sound like plug is too cold. Try a hotter plug.
az00lude is offline   Reply With Quote
Old 05-22-2009, 01:51 AM   #9
losi_racer's Avatar
Trader Rating: 25 (100%+)
x2
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-23-2009, 06:30 AM   #10
thats what i have been thinking. i tried leaning the bottom end and it is still doing it. thanks
Mbx7r, mbx6t(still)
dialedhobbies.com
Old 05-23-2009, 06:57 PM   #11
it was the plug.
Mbx7r, mbx6t(still)
dialedhobbies.com
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
New ACADEMY 1/10 scale 2WD BUGGY rcforum Electric Off-Road 3794 09-30-2013 07:57 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1144 01-04-2010 03:49 AM
1/10th 4wd buggy which one? vwjuice Electric Off-Road 83 08-25-2009 11:24 PM
>>>{LOOKING TO TRADE a Barely used OS V-SPEC and JP-3 Pipe}<<< WYLDTHING R/C Items: For Sale/Trade 28 09-15-2008 05:40 PM
Saint Louis carpet racing!! evostyle Track Locator Forum 368 11-23-2006 08:28 AM
