Old 05-21-2009, 01:26 PM   #1
rcgeezer's Avatar
Default Diff Cleaning Solvent
Other than using nitro cleaner, what solvents or cleaners are you guys using to clean out your diff's when you maintain/rebuild them? Acetone, paint thinner, Simple Green, whipped cream (j/k), oxyclean... help me out here please, it's a mucky mess in there!!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 05-21-2009, 01:37 PM   #2
Naphtha. Available at Home Depot/Lowes. A quart lasts a long time!
071crazy is offline   Reply With Quote
Old 05-21-2009, 01:38 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
elbow grease
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-21-2009, 01:41 PM   #4
Trader Rating: 21 (100%+)
+1 Naptha!!
Cuts it, cleans it end of prob. Works on both grease and silicone.
Duster_360 is offline   Reply With Quote
Old 05-21-2009, 01:45 PM   #5
rcgeezer's Avatar
Interesting...what the heck is Naptha...never heard of it?
Old 05-21-2009, 01:56 PM   #6
Akhor's Avatar
Paint Thinner +1
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 05-21-2009, 01:59 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
Its kinda like acetone but it wont harm anything. It breaks up the oil, making it easier to get off..You still need a scrub brush a towel, and an air compressor to get em totally clean..
Take apart your diffs, and soak everything (not the diff case, or the o-rings) in the Naptha..take out the parts one piece at a time, and scrub em with the brush, or wipe them off, then blast with air, careful not to lose the little shims!..Clean out the diff case with Q-tips, and Naptha, wipe it all off, blow it out..maybe replace the bearings and the o-rings while you are at it..It's always a good idea when you clean your diffs to rebuild them also..New bearings, new O-rings..you'll have smooth diffs always, and no leaks from shot o-rings
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 05-21-2009, 02:07 PM   #8
scwrod's Avatar
I am with Houston on this one. I do not use any products to clean out my diff's.
I tear them down completely and clean each piece buy hand with a rag and sometimes a toothbrush. I have had the same gears in my rc8 diffs for almost 2 years now and I race alot.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 05-21-2009, 02:08 PM   #9
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Gravity... There's no real need to get every spec of old oil out. Just let the diff parts sit for about 20-30 minutes and all the oil will run out. Same with shocks. Just make sure the parts are upside down and on a towel.
RCmayor is offline   Reply With Quote
Old 05-21-2009, 02:45 PM   #10
GMK makes a Diff dunker for like $ 8.00 with a jar of naptha makes it real easy and super clean.
jmpn02 is offline   Reply With Quote
Old 05-21-2009, 02:45 PM   #11
junier00's Avatar
Trader Rating: 20 (100%+)
I clean mine with brake cleaner, then blow with the compressor.
junier00 is offline   Reply With Quote
Old 05-21-2009, 02:45 PM   #12
jkas10's Avatar
Trader Rating: 121 (100%+)
Naptha + Diff Dunker =
a diff dunker is a little metal strainer type cup thingy... Look it up on Amain, or google "tea infuser"...
Put all the little parts in the diff dunker, and stick them, and the diff cup, in the naptha. let them soak for about 15-30 minutes, swishing occasionally. Blow dry the little parts in the diff dunker while the cup is still soaking. Then, blow dry the cup. Should be good.
Don't stick the o rings or gasket in the naptha and use Mobil 1 on the outdrive and back sides of the moon gears when reassembling the diffs.
Makes a messy job easy!
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 05-21-2009, 02:51 PM   #13
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
+1 GMK diff dunker with cup of Naptha.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 05-21-2009, 02:56 PM   #14
Trader Rating: 48 (100%+)
+2 , the only way to do your diffs...
Cyberacer is offline   Reply With Quote
Old 05-21-2009, 04:06 PM   #15
PTP Racing's Avatar
I just use compressed air. I wrap the diff in a towel and stick the air nozzle in and blow it clean.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 09:06 PM
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
Traxxas Slash, SETUPS ONLY ! ! ! ! ! nobike Electric Off-Road 769 09-13-2014 02:35 PM
Cleaning engine and electronics rc-mike Nitro Off-Road 31 04-06-2009 06:15 PM
How you guys clean diff az00lude Nitro Off-Road 57 08-02-2008 11:06 PM
