Old 05-20-2009, 01:56 PM   #1
Default steel vs aluminum flywheel
God help me if this has been posted somewhere but here goes anyway.
Im running the 8ight 2.0 with the stock aluminum flywheel. I am wondering what a steel flywheel would do different with it being heavier. Im still running the stock clutch set up but I am looking at my different options with it. I race on 2 different track surfaces, one is loose and loamy and the other is usually hard packed blue groove. Any and all responses are welcome.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-20-2009, 02:48 PM   #2
jkas10's Avatar
Trader Rating: 121 (100%+)
I run the steel flywheel on my buggy and I can't say that I noticed any HUGE difference, but, in theory, the heavier steel flywheel will tame the engine down since it has to spin up the heavier rotating mass. The steel flywheel also creates more rotating inertia and may help the engine idle smoother.
All of this is probably negated if you run a lightened spur gear and lightened outdrives, etc...
Again, in theory, the heavier the flywheel, diffs, spur, brake disks, outdrives, wheel and tires, etc..... are, then the harder your engine has to work to spool up and break traction. the lighter all those things are, then the easier it is for the engine to get that drivetrain spinning out of control. If you are having issues getting the power to the ground, go with the steel - it can't hurt. It you have plenty of traction, you might try it, but problably will not increase performance.
There are a couple other threads discussing the steel vs. alum flywheel around and you might find more opinions if you can find the threads.
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 05-20-2009, 03:40 PM   #3
I figured there are other threads but unless you know exactly the title it will show 40-50 different threads and usually they are not titled in a way to go straight to it. Most the time it would take alot of reading but then still come up empty.
Old 05-21-2009, 07:58 AM   #4
jkas10's Avatar
No problem, bud. Not hatin' on ya, I just remember seeing it before so I figured someone might refer you to another thread.
I found these that might help:
losi steel flywheel or aluminum
Flywheel Alum vs. Steel??
Old 05-21-2009, 09:07 AM   #5
Tech Legend
Wild Cherry's Avatar
I`v only been able to compare the two on a CvR .12 but I can tell you with a steel flywheel your idle is improved the most .
Found the heavier steel does not really tame wheel spin or enhance the smoothest of the power very noticeably.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1633 Yesterday 11:17 AM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 11:50 AM
Flywheel Alum vs. Steel?? Frank L Nitro Off-Road 12 04-17-2009 11:04 PM
Heaver vs. Lighter Flywheel rmdhawaii Nitro On-Road 69 04-02-2007 11:22 PM
