Old 05-20-2009, 05:35 AM   #1
pl_unc86's Avatar
Trader Rating: 16 (100%+)
Default Fly Wheel Question!
I was installing my mugen flywheel today (just removed the m2c flywheel)..
Is it ok if there is a small gap between the flywheel and front engine bearing? I know you have to have some space period but the gap is big enough i am able to see light coming through.
I didnt think it was an issue but i just wanted to make sure! Thanks
PM
pl_unc86 is offline   Reply With Quote
Old 05-20-2009, 06:00 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
Was the collet pushed all the way to the front bearing before you intalled the flywheel?
Old 05-20-2009, 06:03 AM   #3
pl_unc86's Avatar
Yeah, the manual showed a spacer between the collet and the bearing as well which as also there.
Only reason i could think of the gap was maybe that was a diff collet because of the M2C flywheel...
Its not a large gap but like i said its enough that i can see light coming through.
Old 05-20-2009, 06:09 AM   #4
pl_unc86's Avatar
Old 05-20-2009, 07:12 AM   #5
Frank L's Avatar
If it says use a spacer then use it. As long as the flywheel is tight Eng worry about it. Mount it up and go. I don't use a spacer on my losi 2.0 but it doesn't tell me t either. I thnk it will be fine.
Old 05-20-2009, 08:17 AM   #6
wallot's Avatar
I have a huge gap between front bearing and flywheel as vario 3 flywheel is quite narrow. collet touches the bearing as it's supoposed to but it just looks like vario is made like this. I got two big races with the clutch (about 3 hours of driving time) and everything works well.
collet - 0.3mm shim - bearings and clutchbell has just the right amount of play.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 05-20-2009, 08:41 AM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
Use the collet that came with your kit with the spacer..If you are using the MC2 collet with the stock flywheel and spacer that may give you too much of a gap, you dont want dirt entering your front engine bearing. Get the flywheel as close as you can to the engine
nothing to see here................................
Jaz240 is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11441 07-19-2017 03:19 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 11:50 AM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
ONE WAY DIFFS? What's the big deal? ddd228 Micro and Mini Scales 25 03-02-2009 01:01 PM
