Old 05-19-2009, 07:04 PM   #1
Default O.S. engine stalling out
Here I am trying to tune this engine and nothing i do seems to work. It will idle fine , but when i do a quick throttle it bogs and stalls. If i ease in to the throttle it is better, but i quickly let off and it dies. Ideas? I feel like I have tried everything. Temp is between 200 and 210.
jboehm is offline   Reply With Quote
Old 05-19-2009, 07:05 PM   #2
lean the bottom out some. see what that does.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-19-2009, 07:49 PM   #3
MercyRev's Avatar
Trader Rating: 54 (100%+)
Default tune
yes...
turn the low end needle in a couple of hours at a time until it starts to pick up...run it some more, retemp then you can tune the top for top speed on the straight, temp recheck etc
it shouldn't take much unless you've moved the factory settings a lot
Hope this helps
Jason
Team Xray-O'Donnell Speed Blend Fuel-O.S. Engines-Futaba-Racer's Edge
President-Oklahoma Nitro Club Taylor Park RC Raceway, Yukon OK
www.oklahomanitroclub.com
"Come and race with us!"
MercyRev is offline   Reply With Quote
Old 05-19-2009, 08:01 PM   #4
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Check your clutch shoes, springs, and bearings.... if anyone of those are having issues you'll have stalling issues.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 05-19-2009, 08:40 PM   #5
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I had this exact same problem on my pro mod Vspec. Front bearing seal was gone....leaking very badly!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 05-19-2009, 09:06 PM   #6
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
I also have this problem after run-in a new engine. Full throttle then engine die....change new glow plug also same. After check and found my idle gap are too less(almost close). After I set the idle gap to about 2mm, all the problem "go". And start from there, I managed to tune my engine. Check your idle gap with remove the filter out and start from there.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 05-19-2009, 09:39 PM   #7
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
A 2mm idle gap is much too large on the V-Specs. It should be between 0.5 and 1.0mm. Without seeing or hearing the engine, it's impossible for us to know whether you're rich or lean on the bottom, and it could be either one. If it dumps a TON of smoke and/or spits oil off of idle, then you're too rich. If there's no smoke at all when you stab the throttle, then you're too lean. Experiment in both directions.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Nitro RS4 SS not likin me too much SpeedDemon911 Nitro On-Road 80 04-17-2007 08:06 PM
