Old 05-20-2009, 02:03 AM   #16
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by houston View Post
exactly , did they also tell you they could sell you a new one ?
with the same "problem"
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 05-20-2009, 04:09 AM   #17
Send a message via AIM to RCinSC
Yeah they were READY to order a NEW P/S. I feel like they are trying to drain me. Thanks for the help yall. If any one has any more ideas please let me know. Thanks
RCinSC is offline   Reply With Quote
Old 05-20-2009, 04:10 AM   #18
You had the same problem? What did you do?
Old 05-20-2009, 04:48 AM   #19
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by howtowakeakar View Post
Yep, it is very good. If it goes away after a few gallons, your engine and sleeve are starting to wear, and *might* need to be replaced. Most motors last at least 10 gallons without needing them to be replaced.
At least 10 gallons? I want some of THOSE motors!
I have yet to have a motor last more than about 7-8 gallons, under racing conditions, with a race tune on it.
Bashing might be different...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 05-20-2009, 04:59 AM   #20
DOMIT's Avatar
While I hate to immediately say that they're scamming you... it sounds to me like you have a perfectly good piston and sleeve. You did the right thing by asking here.
When a motor is new, the fit of the piston and sleeve will be VERY tight at the top. The sleeve is tapered slightly... as the motor breaks in, it will loosen up somewhat. When it gets TOO loose, the motor is worn out.
I think I would be cautious about believing anything you hear from that particular individual if not the shop in general. You did the right thing in this case by checking with us here.
Old 05-20-2009, 05:04 AM   #21
This shop is totally trying to sell him off on anything they can, trying to take advantage of a new comer to the hobby. Unfortunately, many LHS's do this. You have to watch out for em'.
I told you so buddy....
TnRCguy is offline   Reply With Quote
Old 05-20-2009, 05:23 AM   #22
Trader Rating: 40 (100%+)
Have you been able to start it yet?
jdeadman is offline   Reply With Quote
Old 05-20-2009, 01:16 PM   #23
My motor is on it's second gallon, and is gaining strength, I expect at least another 10 out of it. Once I get out of school I expect to be going through at least a gallon every other week, so it had better last that long.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-20-2009, 01:46 PM   #24
He was saying the lhs was gonna sell you a new one with the same problem. Meaning the new one would be tight also which means the one you have now is good.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-20-2009, 01:57 PM   #25
No man I havent. Last night when I started this thread is was already dark. But I will thank everyone for the FAST FAST FAST reply to my thread. THANK YALL. I am about to go try the 1/2 turn out on the glow plug and heat it to 200. I will reply the out come.
Old 05-20-2009, 02:40 PM   #26
I went out and tryed the 1/2 turn on the glow plug. I heated it up also. But I still couldnt get it to start. When I heated the motor the drill had no problems turn the motor. Is there anything else to try?
Old 05-20-2009, 03:16 PM   #27
Is your glow plug still good?
LRP Z.28R - 3
Spur Gear - 0
Old 05-20-2009, 03:34 PM   #28
If this is a new engine it will take some effort to get it started. With the problems you are having I would go to the nearest track and ask for help. Most lhs do not have the knowledge to truly help. A racer will be your best help for sure. Its sad they arent knowledgable but thats the way it is most of the time. If you cant start over from scratch and follow the directions to get it started then giving advice over the net won't be much help either. You need someone to help in person.
Old 05-20-2009, 05:38 PM   #29
Smile
Well well well... What a night. I went BACK to the LHS. I know dumb. They burnt up my BRAND NEW HPI DRILL I BOUGHT MONDAY. Still couldnt get it to start. Well he said if you have time let me charge 2 batterys to try the jump box. I said OK. I got to looking at the cars fuel lines. I noticed that the line coming from the tank was pinched by a zip tie. So I was like fuck after you burn up my drill I foind this. So I waited. They close at 8pm. So around 7:20 the batterys where finished. So we tryed the box. ON THE FIRST TIME SHE FIRE AND I WENT NUTSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!! So I rushed home to get all the stuff to the drill and boxs for the charger and battery for the drill. I got a dynamite platinum starter box, the big battery ( looks like a small motorcycle battery ) and charger. So the guy that told me last night THERE CAR TECH that tryed to sell me a piston & sleeve got fired!!!!! SHE RUNS!!!!!!!!!
Old 05-20-2009, 05:51 PM   #30
At least you got it fired!
Bump box + gel cell = MUCH better than darn near anything else out there for starting cars.
LRP Z.28R - 3
Spur Gear - 0
