Old 05-19-2009, 07:40 PM   #16
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by JAMMINKRAZY View Post
Aluminum flywheel. IMO only a high power .28 warrants a steel flywheel in a truggy. Speed is a very smooth engine as it is. You will notice tons more power and better runtimes.
What pipe do you recommend? I have a dyn 053, JP2, dyn 086, GRP 2053 and a trinity bad boy pipe. Also what header for a truggy long or short. I usually run a long header for increased torque is that necessary with this engine?
Old 05-19-2009, 07:42 PM   #17
jpz_67's Avatar
Trader Rating: 56 (100%+)
I have run a 053 and the JP2 on a speed and I felt they both worked great. But ultimately I ended up buying a 2050 for it.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 05-19-2009, 07:43 PM   #18
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Out of those the 053 is gonna be the best. IMO the best pipes for it are the os 2060, losi re11/os 2050, EB 2041, JP-3, or 053. The 2060 will give a smooth powerband with the best runtime. Re11 or 2050 will be punchier with good runtime too. EB 2041 is about the same, maybe a tad less runtime. JP-3 very punchy, but kinda flat in the midrange, good runtime, but less than the others. 053 very smooth, with good runtime.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-19-2009, 08:47 PM   #19
Frank L's Avatar
I'll have to get a 2050 then.
Old 05-19-2009, 08:51 PM   #20
hambone's Avatar
No way does the 2050 work well on the speed motor. Do yourself a favor and buy the 2060. 2050 does real well on regular v spec but kills the speed motor. Been there done that. 2050 kills that sweet top end the speed has.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 05-19-2009, 09:00 PM   #21
Frank L's Avatar
What about the 053?
Old 05-19-2009, 09:02 PM   #22
What about the 053?
If you are going to spend the money on a 2050, best bet is the 2060. That is really the best pipe for the speed.
-Koby Kubrin-
Old 05-19-2009, 09:03 PM   #23
bill marchant's Avatar
Trader Rating: 229 (100%+)
Send a message via Yahoo to bill marchant
Agreed I just put my OS SPEED in to my 2.0T What a difference I think it ran better in my 2.0B Fast as hell in the buggy not enough power for the Truggy....changed the 4 shoe aluminum stock 2.0 setup to 2 steel and 2 carbon setup has a little more low end grunt IMO in that configuration....As always with the speed great run time though
Hobby Pro USA, Agama
PRS1 buggy D3 13.5/Hobbywing
Novarossi/savox
BRUCKNER HOBBIES For All your RC needs 2 FEED YOUR ADDICTION!!!
BARNSTORMERS RC/Gun Hill Racing
bill marchant is offline   Reply With Quote
Old 05-19-2009, 09:17 PM   #24
cary's Avatar
Trader Rating: 67 (100%+)
frank i have a AE 2035 i think it may be like 2050
if you wood like to check it out but some one
out hear may now if it is or not
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 05-19-2009, 09:29 PM   #25
Frank L's Avatar
Thanks Cary. I might have to try it out. I have 5 pipes to try but I don't have a 2035 sounds like a higher torque pipe - lower number (last 2 digits) usually means more torque and less top end, but worth a try.
Old 05-20-2009, 06:13 AM   #26
elcaminosslover's Avatar
Trader Rating: 60 (100%+)
I run the Speed in both Truggy and Buggy. I never had a problem with lack of power in my truggy, I put a 6mm carb. restrictor in it to tone it down a notch. I also run a 5mm restrictor in my buggy engine. My race partner runs a 5 port Novarossi in his Truggy and that thing is a screamer. He runs 2 carbon/2 aluminum shoes in his Losi 8T.
elcaminosslover is offline   Reply With Quote
Old 05-20-2009, 11:36 AM   #27
Frank L's Avatar
Anyone know if I need to add the extra shim that the speed comes with to run 30%?
Old 05-20-2009, 11:50 AM   #28
I believe that shim is just intended for break-in. I myslef run 20% so not completely sure. I don't think it's needed though. I didn't even use it for break-in.
-Koby Kubrin-
Old 05-20-2009, 01:04 PM   #29
PinoyCali's Avatar
I just got my speed today. My friend told me that he put 1copper and 1 silver on his.
PinoyCali is offline   Reply With Quote
Old 05-20-2009, 01:18 PM   #30
Frank L's Avatar
What came stock. I got mine today too and I haven't opened it up yet
