Old 05-19-2009, 11:55 AM   #1
Default Nitro Engine Help
I just got a used CEN MG10 that was previously broken it. I read the nitro tuning guide but still need some help as I didn't get to start from the beginning with this engine.
It will start (took me forever to finally get it started with factory card settings) and idle. If I give it throttle it goes and then dies quickly. There is no visible smoke. Takes a little bit of throttle to finally start moving.
Any help would be great.
edit: When I give it almost full throttle, it barely goes anywhere, but the carb is open all the way.
ieatfish is offline   Reply With Quote
Old 05-19-2009, 12:10 PM   #2
BAUSTIN's Avatar
its hard to tell, it could be a extremely lean bottom, but scince you set ti to factory settings i doubt this is the case, you may want to check the clutch to see if it is hanging it up, if it was a rich bog you should have smoke......how used was it? did you know who had it.......my next step would be pull off the engine and check the compression........and easy way to do this without taking the engine apart is pull the engine off the truck then hold the engine up by the flywheel the compression should hold up the engine for at least about 10 seconds.........hope this helps....
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 05-19-2009, 02:41 PM   #3
Default re
when you give it full throttle is it revving really high or is it real flubbery?if it is flubbery turn the high speed needle in in 1 hour increments till it runs better,if it revs and goes nowhere then you have driveline issues
toofless is offline   Reply With Quote
Old 05-19-2009, 02:54 PM   #4
Yeah, the engine doesn't sound wrong at all. I'm guessing it has something to do with the clutch and/or driveline as well. I'm probably not going to put any money into this truck so I may just have to call it shot. Thanks.
Old 05-19-2009, 02:58 PM   #5
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
It can just be as simple as clutch shoes or bearings... under 10 bucks..
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Which one of these 2 r/c's should i get? Zeeshan Rookie Zone 36 03-17-2009 09:08 PM
General Nitro Engine Question CaptCrunch Nitro Off-Road 9 12-16-2008 05:47 AM
25% vs 30% nitro J.Gonzalez Nitro On-Road 12 03-22-2008 06:01 PM
iRacingWerkz Nitro Fest II @ Turf City(GP Offroad race registration, 21st Oct 2007) iRacingWerkz Singapore R/C Racers 42 10-18-2007 03:52 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
HPI savage .25 starting problem, please help!!! makdaddynuge Electric Off-Road 7 01-21-2005 03:52 AM
