Old 05-18-2009, 03:27 PM   #1
halfman's Avatar
Default Need help with my buggys steering
I have a mbx5r and i have my front wheel toe out quite a few degrees and it is still not getting much steering. Any ways to get better steering?
halfman is offline   Reply With Quote
Old 05-18-2009, 03:35 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
lessen the rear toe
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 05-18-2009, 04:11 PM   #3
halfman's Avatar
ok thanks ill try that
Old 05-18-2009, 05:49 PM   #4
Check your servo saver nut, that it didn't back off.
clebo3 is offline   Reply With Quote
Old 05-18-2009, 10:37 PM   #5
Well there's alot of thing you can do to get more steering out of your buggy. If you already have a good servo for steering then we can cross that off the list. If not then you might wana invest in a better servo. As far as set-up goes to increase overall steering you can change your ackerman setting, your dual-rate on your radio, softer front sway bar, front shock tower angle, front caster and of course your tires (making sure you have the correct tire choice) for where you are running your buggy.
Losi-Runner is offline   Reply With Quote
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 07:17 PM
