Old 05-18-2009, 03:48 PM   #16
tc5 man's Avatar
a sg crank shaft fits pretty much anything and it uses a diffrent pilot shaft than a rotary carb, a standard shaft doesnt fit every model and uses a diffrent pilot shaft also and its threaded also. get the sg crank shaft ,i dont think u have to use a diffrent ball end i think the linkage is the same so u should be fine with that but u proberty will have to change the linkage a little but for a rotary carb .
Old 05-18-2009, 03:54 PM   #17
I will continue to research these things online. Thanks for the help so far...
jatojoe is offline   Reply With Quote
Old 05-18-2009, 04:03 PM   #18
tc5 man's Avatar
i think the only thing u use diffrent for a rotary linkage is use a l shape servo horn
Old 05-18-2009, 04:16 PM   #19
Just seems weird the way it sits on there it doesn't look like it would be easy to get the linkage to work...anyway does anyone else have experience with the Dynamite Platinum .12???
Old 05-18-2009, 04:18 PM   #20
tc5 man's Avatar
i would use the search on the top and put dynamite platuim .12
Old 05-18-2009, 04:23 PM   #21
tried that mostly get the .21 stuff but, it looks like the guys that have run them like them.
Old 05-18-2009, 04:32 PM   #22
tc5 man's Avatar
i have run in my gt2 and had about 1 in a half gallon of fuel into it and i run 25% nitro i had a associated .15 and that thing was wicked fast on the track i mean to much
Old 05-18-2009, 08:57 PM   #23
Yeah, I think a .12 is the ticket for this thing.
Old 05-18-2009, 08:59 PM   #24
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
I'm not sure there's room in the Jato for a rotary carb conversion, is there?
Nothing wrong with a slide carb... Just learn to move your finger less
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 05-18-2009, 09:01 PM   #25
tc5 man's Avatar
are u gone to need a starter box for that engine i would get a ofna blue box its for 1/10 and 1/8
Old 05-18-2009, 09:01 PM   #26
tc5 man's Avatar
and get a 12v gell cell battery
Old 05-18-2009, 09:09 PM   #27
I have no idea, but it looks like it should. There is quite a bit of room right in front of the carb, so I will see. I have no problems running a slide mainly for the fact I don't know what I am missing with a rotary.
Old 05-18-2009, 09:13 PM   #28
tc5 man's Avatar
its up to you u can always put a carb insert in if u use the slide carb still or u can turn down the throttle epa, but the rotary carb is much better for 2wd truck
Old 05-18-2009, 09:16 PM   #29
drperry's Avatar
Apparently, the rotary has a slower response, if I read the earlier post right... Which could make the Jato easier to drive...
Old 05-18-2009, 09:22 PM   #30
I think that is how it is? But in return it smooths out the power...
TRADE!!!!!!!!!!!! supratrdlova R/C Items: For Sale/Trade 30 01-07-2009 06:09 PM
Fast Engine ccordero85 Nitro On-Road 58 11-15-2008 05:29 PM
Did nitro hurt the hobby??????? TCRacer101 Electric Off-Road 64 09-09-2008 10:37 AM
Best 1/10Th Offroad Truck Kit xsxracing Nitro Off-Road 69 11-30-2007 11:22 PM
Lots For Sale Mostly New in Box or hardly used RCNUT R/C Items: For Sale/Trade 31 04-17-2007 08:10 AM
Who has a JATO? revzalot Electric Off-Road 89 05-24-2005 03:07 AM
