Old 05-18-2009, 11:17 AM   #1
cameronspruill's Avatar
Trader Rating: 20 (100%+)
Unhappy RC8 QUESTION
I have an RC8 buggy and I'm wanting to find out what combination of pistons,springs and oil do I need to use in order to have the shock collars all the way up and still maintain the no boucing that I have now. I am running 40 wt. in the front with silver springs and 35wt. in the back and black springs.The combination has pretty well eliminating the bouncing but I have to push the collars almost all the way down to ride level. What can I use to have the same feel but pull the collars up?
cameronspruill is offline   Reply With Quote
Old 05-18-2009, 11:56 AM   #2
JoeyTheRocket's Avatar
check out this page: Team Associated 1/8 scale Buggy Info and Tips
The start of the thread has help with the stock shocks and the end has info in the 16mm shocks.
Joey Kubat
AE / JConcepts / Futaba / A-Main Hobbies / NitroPro
JoeyTheRocket is offline   Reply With Quote
Old 05-19-2009, 11:28 AM   #3
Unhappy SHOCK PROBLEM
I just would like to know what oil and shock combination do I need to run so I can pull my shock collars all the way up and still ride level.
Old 05-19-2009, 11:33 AM   #4
PTP Racing's Avatar
The shock collars are there to set the ride height. Whats wrong with having to have them down?
You can use stiffer springs which would probably not require the collars be so far down but its going to change how the car handles.
Are you talking about with the big bores? Is your car nitro or electric?
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-19-2009, 11:34 AM   #5
PTP Racing's Avatar
To do what your asking you would need to find longer springs than the ones AE makes.
Jason Miller
Old 05-19-2009, 11:34 AM   #6
PTP Racing's Avatar
Oil and pistons have no effect on ride height.
Jason Miller
Old 05-19-2009, 11:41 AM   #7
t0adman's Avatar
It sounds like the question is more aesthetically motivated than performance motivated.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 05-19-2009, 11:46 AM   #8
PTP Racing's Avatar
Or it could be electric. The electric buggy is heavier and with those soft springs I could see them being fully loaded and still not giving much ride height.
Jason Miller
Old 05-19-2009, 11:52 AM   #9
Or he can read the thread that's already started (like everyone else has done) to get the inside info!
Joey Kubat
Old 05-19-2009, 12:11 PM   #10
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I'm just curious on why he's asking that specific question. What's the deal?
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 05-19-2009, 12:47 PM   #11
t0adman's Avatar
[Team Terribles]
Old 05-19-2009, 04:45 PM   #12
Unhappy shock problem
Look guys I know what I'm asking is possible to do I'm just trying to find someone who knows how. I want them all up so I have as much suspention tavel possible.
Old 05-19-2009, 06:57 PM   #13
SkarTisu's Avatar
The good thing is that the suspension travel isn't limited by the position of the spring collar. It's limited by the length of the shock shaft. You could have the spring collar all the way down on the shock body and still be able to compress the shock as far as you can with the collar all the way up.
Marshall Skare
Old 05-20-2009, 06:23 AM   #14
PTP Racing's Avatar
Cameron why dont you give us some background on what set-up your running and maybe a picture of exactly whats going on. Your not getting the responses your looking for because its an odd request and the info you have offered is minimal.
You have 2 team guys here trying to help give us something to work with.
This is a picture of my buggy and how the springs are set to give proper ride height. There is no reason to have the spring collars all the way at the top. They are there to be adjusted to give proper ride height and have no effect on the shocks ability to reach full travel.
Jason Miller
Old 05-20-2009, 08:34 AM   #15
Jason how far behind the front of the rear tower is the front edge of the wing ? 25mm or more ? Buggy looked good in the video and looks good in the photo.
Chris Reilly is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
D8 vs RC8 vs X2 Twiztid Rock Nitro Off-Road 36 04-06-2009 08:22 AM
Need more run time on Losi buggy DUBLNIKL55 Electric Off-Road 7 03-08-2009 10:09 PM
RB S5 L2G mixedguy Nitro Off-Road 12 09-22-2008 04:02 AM
