Old 05-17-2009, 05:06 PM   #1
Default Air in fuel line
Hey guys I keep picking up air in the fuel line it will be ok for a little bit then the idle starts surging and really leans out I'll look down and there are air bubbles in the line before the carb. Is a bad pickup in the tank the only thing that will cause this? I've changed the fuel line several times and this does not help. This is my first nitro anything and of course I can't come close to tuning it this way.
If it is the pick up is replacing the tank my only option
Cen matrix with the corsa 5.0
Gary
B/SRACIN is offline   Reply With Quote
Old 05-17-2009, 07:26 PM   #2
xlgraphicspro's Avatar
a couple things can cause this. 1. your tank isn't sealing shut when closed all the way. 2. pin hole in your fuel line. 3. Dirt, or a slight obstruction in the nipple where the fuel line attaches to your carb 4. this one is far fetched, but your exhaust pipe could be damaged internally, and your back pressure is getting messed with. I had an o.s. 2050 pipe, and the inner cone came loose, and cause erratic characteristics such as your talking about.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-17-2009, 07:44 PM   #3
Hi thanks for the reply
I have ordered a new fuel tank to eliminate that portion. Thanks for the tip about the pipe. On the cen r2 it is a composite pipe with an o ring in the middle where the two halve join so you have given me some new areas to check if the new tank doesn't fix the problem
Thanks again
Gary
Old 05-23-2009, 05:18 PM   #4
Just a quick follow up
I replaced the tank the first thing I noticed: I had to blow much harder on the pressure tube to get the fuel line to prime I took this as a good sign. After getting her started up the idle was much to fast, I was able to adjust it and actually see a change. After getting the idle where I thought it should be I was able to do some small adjustments on the HSN and see improvements I was able to drive it around for half a tank making small adjustments and have them work. Nice to have a non surging leaning out beast. The future for this car looks brighter now
Gary
Old 05-23-2009, 06:12 PM   #5
air8's Avatar
Thanx for the follow-up. Always nice to hear how the problem gets solved. That leaves info for us readers.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Announcement: ROAR ON ROAD FUEL NATIONALS - 8TH RACERS OF TOLEDO Dawn Sanchez Nitro On-Road 703 09-17-2009 06:19 AM
AD2!!!Gas Truck Saleout!!!Day Old!!! party_wagon R/C Items: For Sale/Trade 9 03-27-2009 02:25 PM
pressure line question Baedarlboo Nitro On-Road 18 03-20-2008 01:43 PM
Tank pressure Questions SteveG Onroad Nitro Engine Zone 15 07-20-2004 07:25 PM
