DREAUX'S PERSONAL THREAD
#346
someone help me. I am having an engine bog problem with all my engines it seems. Vspecs and ninja. What is happening is once the engine is warmed up the idle drops to a very very low idle. Not a gurgle like it's to rich, but more like it almost wants to die and is barely hanging on and it's not very loud at all but almost quiet. And of course if i let it keep going it will die and it does not take that long to do so.
This is pretty much at just about 100% performance, and i have tried to richen and lean it but it does the same thing. The only difference is how long it takes for the idle to drop and make that sound and then die. I consider myself a pretty good tunner and the engines are in great shape. The only thing i can think of is that it is supposed to sound/act this way. THe first vspec i had did not sound like this at all on idle. But it was my firt vspec and i really did not how to tune.
is this ok? I thought it might be a lean bog since it doesn't sound blubbery but still acts in the same way and seems to have the same effect.
engine runs great and has good smoke and temps around 230. but i feel like i am missing something. maybe i am just crazzy. but it is driving me nutts.
#347
#348
#349
the idle gap is already set fairly big, but i did try a quater turn with no effect. A half turn seems an awful lot for a gap that is already to big imo. I have tried leaning the low speed and that did not help either. Actually made it worse. Richening did not help either
#350
I will be at watson for the night race saturday. You going to be there? I hope it's better lighted.
#352
hope you are right. I always set my idle gap first and it's usually less then one milimeter. I don't know why it was open bigger. But when i close it, it doesn't get any better. Will retune everything tomorrow and see how it goes. Thanks guys.
#354
i did not check the tank. This particular tank is an old tank on an older car, so that may very well be the problem. Except it's doing it with my ninja too. Maybe i have 2 bad tanks. I will definitley check for the bubles. I have checked the tanks for leaks and couldn't find any. But the bubbles would mean i have a leak right?
#357
#358
#360
what brand of fuel do you run ? some fuels idle very poorly..... This last weekend one of the locals was having issues with 2 of my modified engines...originally he blamed the engines, however once I got my hands on it we found his fuel was the problem...He was running the new Blue Thunder Race and having nothing but issues, i switched him over to Odonell and the issues went away....Not all fuel is the same...I have had nothing but issues with BLue Thunder and Sidewinder.....
