Old 05-23-2009, 03:41 PM   #151
Originally Posted by tunerjetta29 View Post
That is assuming the person your talking about is even competant enough to learn anything in the first place.
sorry that shoe doesnt fit. Nice try though. different fuel and new clutch etc. It needed to be tuned a bit anyway. They guy at the track made 1 adjustment. It still wasnt running the way it was supposed to THE VERY NEXT DAY. It has been doing nothing but flaming out. And dieing.
dreaux is offline   Reply With Quote
Old 05-23-2009, 04:09 PM   #152
That's because you're retarded and took it all apart and ran it threw puddles!! You cant expect your motor to last if you bash on it either. you just need to pick up a Tyco so you wont have to post on teh internet how everything is crapping out on you
Traxxas super speed is my weapon
Ryan Roma is offline   Reply With Quote
Old 05-23-2009, 04:34 PM   #153
Jaz240's Avatar
Trader Rating: 52 (100%+)
Dreaux, here comes the part when you spend more money! Take your engine out of your car, take off the clutch and flywheel, and send it to one of many engine guys...while its gone, go get a $100 sport engine and break it in, learn how to tune, and learn what you are doing..when your V-spec comes back from the Mod guy, put it on your shelf filled with after run oil, and sealed in an air tight bag..In a few months when you know what's up..switch back to the V-spec, and use the cheep mill as a backup..Either that or throw away $300, and then spend another $300 and watch that go up in smoke also
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 05-23-2009, 04:40 PM   #154
jrwoodchuck's Avatar
3 $100.00 engines or 1 $300.00 engine, the three engines will give you more opertunitys to learn how to tune.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 05-23-2009, 04:55 PM   #155
Jaz240's Avatar
There's some Screaming cheep engines out there today. The Dynamite Mach 427, the Hyper .21 8 port..I still use the Hypers as Back up engines. $120 and it will keep up with a vspec on the top end
Start shopping Dreaux
Old 05-23-2009, 06:32 PM   #156
Hey, the Hypers are surprisingly good! I was fooled by the dull look of the cranckase (looks are everything to me), until my LHS owner told me to give it a shot. A great buy Get an OFNA 053 pipe with it dreaux
cheapskate.brok is offline   Reply With Quote
Old 05-23-2009, 07:06 PM   #157
smracer31's Avatar
Send a message via AIM to smracer31
i guess ill be the first to try and help you with your current problem
There are a lot of reasons why your motor will cut out. My first tip is replace your glow plug. Often if your engine has been run to lean or rich it will break down the element at the end of the plug and it will lose its conductivity. when you rev the engine if the glow plug cant stay hot enough the engine will flame out. So swap the plug with a brand new one. The next step is setting the needles to their factory settings, set the lsn, hsn and the carb gap. from there begin tuning and hopefully all goes well, post back if the plug doesnt help.
smracer31 is offline   Reply With Quote
Old 05-23-2009, 07:40 PM   #158
Lenard's Avatar
Smash it with a rock!
Lenard is offline   Reply With Quote
Old 05-23-2009, 09:52 PM   #159
never seen someone have so many issues
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 05-23-2009, 10:00 PM   #160
you haven't met me then!!!!
Doug
TLR 22/M-11
Old 05-23-2009, 10:02 PM   #161
this plug is practicaly brand new. has about 8 tanks on it. although it was doing the same think before i replaced the last one. I went back to factory settings already. It has to be one of a couple things. 1. the crankcase is cracked (i fliped the car pretty bad and it put a dent in my muffler), 2. air leak in the carb, even though the screw is tight that was one of my problems before, it is tight but once i start to loosen it, it's well loose. 3. P/S lost compression.
It could also be a fuel system leak. I have checked the best way i can. but have not found any leaks. I am not giving up. worst case i send it off to O.S to get it serviced.
Old 05-23-2009, 10:14 PM   #162
Jaz240's Avatar
Dont send it to OS, send it to Brian at Pro Twister Mods
Old 05-23-2009, 10:20 PM   #163
ok jazz. thanx
Old 05-24-2009, 01:55 AM   #164
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
Get an Axial .28 or something similar... Hard-ish on fuel, but a reliable engine for a budget price, and you can learn to tune on that, that way, your nice .21 stays nice until you get tuning down
Also, tuning by sound only works for some people, others need to tune by smoke, or feel, and most by temp.
Not everyone is sensitive to sound
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 05-24-2009, 04:06 AM   #165
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Wise choice....he won't BS ya either. If it's junk...he'll tell ya it is instead of tryin to get your money.
skeller is offline   Reply With Quote
