Old 05-16-2009, 05:00 PM   #1
Default is 260 to hot for a vspec???
I was told by the guy who sold it to me, to not let it get hot. I understand running temps for engines is anywhere between 2 and 3 hundred. MY friend who has been racing for a long time says if i have not got it up to 280 i can still get more out of the engine and have not maximized the performance. But i would like to keep mine on the rich side of good running. I could only get it up to 230 before i got it running right, but now it runs much better. Is this a good operating temp?? it never went over (maybe 265)
dreaux is offline   Reply With Quote
Old 05-16-2009, 05:07 PM   #2
jrwoodchuck's Avatar
to hot for me,, i like 220-230.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 05-16-2009, 05:14 PM   #3
what actually happens to a engine when it reaches 300 or better???? just curious. Does it melt or something???
Old 05-16-2009, 05:23 PM   #4
All the oil gets burnt off in the engine, instead of it actually lubricating stuff. Engine overheats and seizes.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 05-16-2009, 05:24 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Agreed. that v-spec will make plenty of power and runtime for you at around 230. Running lean will not provide enough lubrication. this can cause the engine to overheat or seize. If you overheat it you will lose compression and the engine will have a shortened life span. You have already done enough to the engine. I would definately richen it up a bit.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 05-16-2009, 05:30 PM   #6
For you...yes. For a competitive racer who doesnt mind replacing engines more often and needs the extra performance...no. The Vspec is plenty fast at 200-230. If you dont mind going through motors, go for it. When a motor runs hotter than its designed for (300+), the piston expands more in the sleeve and wears out faster and is also tougher on bearings due to the extra temp and RPMs. To answer your question that was already answered in your other threads, yes its too hot!! Try to tune 210-230.
and remember to keep clean panty hose on...
gizzo101 is offline   Reply With Quote
Old 05-16-2009, 05:31 PM   #7
I agree that you should be making decent power at 220-230. Also, if you are running a bit hot, you are also accelerating the wear on your bearings as well. Vspecs have a history of eating bearings so check you bearings from time to time.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 05-16-2009, 05:37 PM   #8
how do you know i have panty hose on my filter?
Old 05-16-2009, 06:04 PM   #9
HulkNT1's Avatar
ok so explain engine that like to run hot like the Go Tech engine if you do not get them up to 260 they will not run good.. Is this temp for all engine or are there engine that suppose to run hotter than others and how do the customer know this? In the engine manual it does not say running temp.. Does the manual for the V-spec say 230???
HulkNT1 is offline   Reply With Quote
Old 05-16-2009, 06:17 PM   #10
All engines are pretty much the same, unless specified by the engine manufacturer. Even then for the most part they are the same. It is the same principal/process in all engines. Depending on the matterials used the temp threshold may be different. In general I like to keep all of my engines under 250, with 210-230 being the optimal tune. If the engine doesn't perform well at that temp, you may want to look into something being wrong with the engine or tune.
-Koby Kubrin-
Old 05-16-2009, 06:19 PM   #11
no the manual doesn't say. That is why i am asking. But people here say i ask to many questions. But this is a forum. forums are for asking questions. Rctech forums is for nitro cars. I have a nitro car. so on and so on. I have a hundred more questions. But must let it out at a pace they can absorb.
Old 05-16-2009, 06:19 PM   #12
Some motors need to run hotter to make good power. They also usually dont last as long. Vspecs make good power from 210-220 and up. they just get even faster as they get hotter. If someone knows how to tune one properly, its not a problem to run them 270-280-290 but inexperienced tuners will end up running them hot and wasting them
Old 05-16-2009, 06:22 PM   #13
not if they make sure they don't get to hot.
Old 05-16-2009, 06:37 PM   #14
Havent you even considered a question thread just for you? Then you can ask all your questions, without clogging up the forum with 10 threads on the first page.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 05-16-2009, 06:45 PM   #15
thats what Im talking about, one thread just for dreaux then there wouldnt be so many to sift thru.
Making a comeback !!
roadracer43 is offline   Reply With Quote
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
RC8/V-spec tuning CaptainHowdyt13 Nitro Off-Road 11 06-16-2009 04:44 AM
