Old 05-15-2009, 07:43 PM   #1
Default Loose High Speed Needle/Screw
Howdy there, my high speed screw used to have a bit of resistance when I adjusted it, I haven't had the buggy fired up for around a month, I started it up today and had a bit of a run and then it started boggin down at full throttle. Had a look and noticed that the screw was wound in nearly all the way. Adjusted it back out and when I was doing that noticed it was very loose and easy to turn. Went for another run and it did the same thing so I bring it in and notice that the screw had wound in again. Anyone know what has caused this and how to stop it winding itself in?
Redsea is offline   Reply With Quote
Old 05-15-2009, 07:51 PM   #2
might need a new o ring. But i don't know that much. I know they can detierorate. And is main factor in the needle having resistance. Don't know if i was any help
dreaux is offline   Reply With Quote
Old 05-15-2009, 07:59 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
definitely need new orings
houstons engine service
i can replace them if you send to me
what kind of engine ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-15-2009, 08:15 PM   #4
Houston thanks for the information, but ummmmmm I am in Australia, so I dont think I will be sending it to you for new o rings
Old 05-15-2009, 08:48 PM   #5
Trader Rating: 117 (99%+)
Send a message via Yahoo to penguineman
yep just order some new orings and replace them. should take care of it.
penguineman is offline   Reply With Quote
Old 05-15-2009, 09:06 PM   #6
houston's Avatar
that would be a no
maybe i can fly over there
Old 05-15-2009, 11:50 PM   #7
MrUnlimited's Avatar
Right, very simple to do.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
I have to rant listen if you like dreaux Nitro Off-Road 49 05-05-2009 09:44 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 09:42 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
